Problem with right click on programs pinned to taskbar.
  1. Posts : 34
    Hello.
    I hope I'm in the good section for my post.
    When I right click on Windows Media Player on the taskbar, the recent files and task lists appears, but don't work : when I click on a file or a task, nothing happen .
    However, it worked at the beginning (just after Windows installation), and it still work for other programs.
    I tried a system restore, and the problem persist.
    I'm on Seven Beta 1 (Build 7000).
    Could you help me? Thanks.
  2. Posts : 3,141
    Try doing a system file check. Info if needed: SFC /SCANNOW Command - System File Checker
    If you have done any hacks, you will probably lose them, but then that may be the problem.
    Gary
  3. Posts : 34
    I followed your advice and tried a System File Check.
    It found some errors and repaired them, but the problem persists.
  4. Posts : 1,009
    Windows 7 RC 7100 32bit/64bit
    Have you tried to unpin Windows Media Player from the taskbar and then pin it back again?
  5. Posts : 34
    I can pin and unpin Media Player, but I've still my problem (even after restart).
    I've the same "bug" with Live Messenger (2009), which is not pinned to the taskbar...
    I don't know what to do...
  6. Posts : 34
    I found the correct word for my problem : there are the Jump List of Media Player and Messenger which not work...
    Any idea please?
  7. Posts : 18,404
    Have you taken a look at Brinks tutorial? It says you have to have Recent Items and Recent Programs on for it to work. You can also do a repair install if things are not working properly, might fix it.
    Jump Lists
    Repair Install
  8. Posts : 34
    Thanks.
    I will try...
    Doesn't work.
    I was this problem on Build 6956 and the upgrade to Build 7000 didn't fix that.
    I already sent feedbacks to Microsoft, but actually I can't use Jump Lists of Media Player and Messenger. Files are here but links don't work ...
    I decided to reinstall cleanly Windows and I recovered Media Player Jump List.
    I found why I had this problem : it's an incompatibility between a-Squared Anti-malware and Windows Seven.
    My problem is now fixed :)
  9. Posts : 4
    7
    I have the same problem with jump list with media player and messenger.
    I have tried a repair install same problem?
    Any ideas as it is driving me mad. Jump lists work with internet explorer and windows explorer.
  10. Posts : 34
    I found why Jump List didn't work: because I installed programs which "deactivate" Jump Lists (except Internet Explorer and Windows Explorer).
    Did you installed A-Squared or Systran Translator (program, not gadget) on your computer? If yes uninstall it, or restore your system to a date before installation. If no, what program?
