Mak, lets reinstall the Nvidia drivers in this fashion. It will give you the cleanest install NVIDIA Drivers - Avoid Problems
Next, please go into BIOS and tell me the value of the +12V, +5V and +3.3V also tell me the temp readings of the Motherboard and the CPU.
When you had the BSOD did it tell you the display driver stopped working first?
Also please download Ungine Heaven 4.0 and install it. After the driver install, run the benchmark using the preset extreme. It should look like this.
Once it starts you can click the benchmark button to start the benchmark. Save the results and uoload a screenshot of the results. This will tell you how. Screenshots and Files - Upload and Post in Seven Forums
