Missing power state controls in advanced power plan settings
  1. Posts : 25
    Windows 7 Professional
    Hi guys, I'm new here and this is my first post. I have an Optiplex 745 running Windows 7 Professional. Normally in the advanced setting section of the power plan option I have the option to change the power state, however all of a sudden these options have just totally disappeared. Any help is appreciated.
    Thanks in advance.
  2. Posts : 13,576
    What Power plan are you using ?
    Balanced, Power Saver or High Performance ?
    Also, run a System File Check
    Use option 2
  3. Posts : 25
    I am using High Performance. I am not getting the option in any powerplans.
  4. Posts : 25
    I have tried the fix stated in option 2 but still no luck unfortunately
  5. Posts : 122
    Hello Kaamo,
    Thanks for posting your question.
    Is this a most recent issue you are experiencing? If it is, why not try to system restore to before it was happening?
    1. When turning on your computer, continuously tap F8
    2. Select Repair Your Computer.
    3. Select System Restore.
    Make sure to restore to before the issue was occurring.
    Thank you,
    VinnyBuxton
  6. Posts : 25
    Brilliant, Ill give that try now and see if that solves it. Thankyou.
  7. Posts : 25
    A system restore hasn't fixed it unfortunately.
  8. Posts : 122
    Hello Kaamo,
    Please post a screenshot of the issue. Screenshots and Files - Upload and Post in Seven Forums
    Thank you,
    VinnyBuxton
