small aesthetic problem :)
  1. Posts : 30
    win7x64
    you know like how you can click on an icon in the taskbar, hold left mousebutton down and pull the menu up with moving the mouse upwards?
    i think tuneup killed that for me and it doesnt seem to work anymore. but it was so slick anyone an idea to restore it? re-enabling all animations in tuneup didnt fix this small problem
  2. Posts : 5,747
    7600.20510 x86
    System Restore
    It's not advisable to use apps like that unless you know how to manually fix when things go wrong, as in this case.
  3. Posts : 137
    Win7 7600 x64
    Were you using Tuneup utilities 2009? As this was not compatible with Win7. The new 2010 is and does not mess up your system.
    Does the right click on the icon still work? As this achieve the same thing.
  4. Posts : 30
    win7x64
    yeah i used 2010. the functional aspect of it still works (right click) but i just loved the animation
  5. Posts : 137
    Win7 7600 x64
    Have you checked the animation and effects settings in Tuneup? Perhaps an optimization has caused it to stop? I am trying mine now to see if I can turn it off and on again by going through the settings.
