System will not boot with secondary hard drive connected
  1. Posts : 2
    I have two hard drives, a 240 GB SSD with the OS, and a second internal hard drive, a WD black edition 2 TB drive.
    Everything worked fine until I temporarily attached a friends hard drive (OS drive running Windows 7 prof) to my system in order to recover some files. After removing the friend's hard drive, my system hangs-up after the motherboard splash and will not boot. If I disconnect my WD drive, the system boots normally. If I disconnect the WD drive until the Windows logo appears, then connect the WD drive, the system boots normally, and the WD drive works fine.
    What do I need to do so I don't have to disconnect/reconnect the SATA cable from my secondary drive(WD) every time I reboot the system?
  2. Posts : 13,576
    Could you post a shot of Disk Management with both drives connected please.
    Disk Management - Post a Screen Capture Image
  3. Posts : 5,656
    After posting the screenshot AddRAM requested, try loading defaults in BIOS (first screen or exit menu) and reset the harddisk boot order.
  4. Posts : 2
    OK guys I will try to do ask you requested later when I get home.
    Thank you.
  5. whs
    I think GokAy is right. It is a problem of the BIOS boot order. On most systems you get into the BIOS settings by pressing F2 when the splash screen appears. But check on your splash screen - some systems are different.
