Extend Volume on C: Drive grayed out, can't extend volume.
  1. Posts : 2
    windows 8 x64
    I took my Acer Laptop to the computer shop to get my SSD fixed and when they finished it and got it home i noticed my drives where split into 2 drives of 50GB approximately; C: & D:.
    I have been trying to merge or at least give some space to drive C: , but my extend volume button in the partition manager is gray, even tho i have allocated space.
    please give me some advice.
    Attached Thumbnails Attached Thumbnails Extend Volume on C: Drive grayed out, can't extend volume.-partitions.jpg
  2. whs
    Disk Management will not do the extension, but Partition Wizard will do it.
  3. Posts : 20,583
    Win-7-Pro64bit 7-H-Prem-64bit
    Hi and welcome to SevenForums,
    A very small drive
    As stated free mini tool can do this but in all honesty you need fewer partitions and a larger drive ultimately
    Best Free Partition Manager for Windows | MiniTool Partition Free
  4. whs
    I suspect this is an SSD. It may be OK for the purpose but it has far too many partitions on it..
  5. Posts : 6,330
    It looks like there are 3 Recovery Partitons
    Unless they can explain why and show how they work, I wouldn't use or trust that computer shop again
  6. whs
    I have seen that several times recently - the 3 recovery partitions. Seems to be something legit. Not sure I understand how they work together. If you make an image, you will need none of them,.
  7. Posts : 20,583
    They are all empty
  8. Posts : 6,330
    It's the first i've seen with 3 recovery partitions.
    From the little searching i did, on some systems Windows will create the 3 recovery partitions when upgrading from Win 8 to Win 8.1
    The OP specs show Win 8 as the OS.
  9. Posts : 2
    windows 8 x64
    solved
    partition wizard worked cheers guys (y)
  10. Posts : 20,583
    I'd look into this and get rid of all of those useless little partitions,
    Gain another gb in the process
    Bootmgr - Move to C:\ with EasyBCD
