how to make Power icon only visible when on battery
  1. Posts : 8
    windows 7 Ultimate
    Hello,
    I'm used to see (Windows XP) the Power icon only when working on the battery of my laptop.
    With Windows 7 it's always visible.
    Is it possible to make is disappear when I'm not working on the battery?
  2. Posts : 428
    Windows Seven x64
    Hi robba,
    I am not sure what icon you are talking about exactly...
    Are you talking about the Battery Icon in taskbar?
  3. Posts : 8
    windows 7 Ultimate
    thanks for your reply.
    yes I don't want this icon.
    but it turns into this icon below when I'm working on my battery. and this is the only one I need.
    Attached Thumbnails Attached Thumbnails how to make Power icon only visible when on battery-windowsicon.jpg
  4. Posts : 1,705
    Windows 7 Ultimate x64 ®™
    Then don't plug your laptop in.
  5. Posts : 8
    windows 7 Ultimate
    I have never seen this icon with Windows XP so it would be great to have this with Windows 7 as well.
    Don't plugin in the laptop is nonsens.
  6. Posts : 1,705
    So is only wanting to see the icon when you're on battery, when it's an almost identical icon.
  7. Posts : 8
    windows 7 Ultimate
    yes but most of the time I don't work on battery and it bothers me because it has no function.
    and no I'm not gonna add the icon when on battery.
    but why would you care.
    I just ask if it's possible just like as in Windows XP I don't want a discussion wheiter I shouldn't care about the icon.
  8. Posts : 9,582
    Windows 8.1 Pro RTM x64
    Hi robba and welcome to Windows 7 Forums
    Sorry, but that is not possible. You can either have the icon displayed or not.
  9. Posts : 1,705
    Right click on it and turn it off then.
  10. Posts : 428
    Windows Seven x64
    robba,
    The only way to turn off this icon is by Right-Clicking on the icon and click Turn off System Icons, A Window will pop up and then you can have a choice to either turn it off or on, Meaning it will remain off when when you have your laptop on battery.
    I don't think there is a way to have come on when the battery is on. and Turn off when you are not using the battery.
    Hope this Helps...
