Help, permament power save mode.
  1. Posts : 4
    azndragon9k
    Yesterday I was trying to figure out what was wrong with my Nvidia Geforce 8800 Gt, so I went to the BIOS, and I accidently set the primary display, or whatever it was called to Onboard. So know my moniter is always on power save mode.
    My computer is a HP Pavillion, SMD Athlon II X2 Dual-Core, 4 Gb of ram, and 620 GB of space.
    Thanks for the help!
  2. Posts : 135
    Windows 7 Ultimate 32-bit Version 6.1 (build 7600.16385)
    Well, have you tried reverting back what you did in your BIOS to see if the problem still persists?
  3. Posts : 4
    azndragon9k
    Alwin, the problem is that when I turn on my computer. The moniter is still "power saving mode", and the moniter is plugged in. So am unable to see what am doing.
  4. Posts : 19
    windows 7 64 bit home premium
    You will need to plug your monitor into the onboard graphics out socket. Then you can change your bios back. Then reconnect your monitor back to your graphics card.
  5. Posts : 4
    azndragon9k
    Erm, a really dumb question, but I dont remenber which one is the onboard outlet.
  6. Posts : 4
    azndragon9k
    Nevermind, I figured out which one is the onboard outlet. Thanks for the help! By the way, do I ask for a admin to close the thread or do I close it myself? As you can see by the post count, am new.
  7. Posts : 19
    Computer hardware poster 1.7 by =Sonic840 on deviantART
    Its usualy a blue one. See ports on this poster vga/svga
  8. Posts : 11,990
    Windows 7 Ultimate 32 bit
    Click on the red triangle in the uper right of your post. Ask a moderator to please mark the thread as solved.
    Glad you are up and running again.
