Help please! Shortcut icons problem...
  1. Posts : 14
    Windows 7 Pro
    I need your help. I was "playing" with icons, icon packages and so on...but after doing I don't know what I noticed that my desktop icons and other folder (mainly applications) icons changed their look. Now they have some addition - something like a small white CD disc in front of small white package. I think that this little white "package" is changed shortcut sign (before there was a black arrow in white box). I would like to restore previous look of shortcuts... but I have no idea how... I appreciate your time and help I also attached a picture of some of my desktop icons it this can help... Many thanks!!
    Attached Thumbnails Attached Thumbnails Help please! Shortcut icons problem...-1.jpg
  2. Posts : 17,796
    Welcome
    If it is just short cuts, try with one first, to see what happens; delete it and create a new short cut.
    better yet, create a new short cut first and see what happens. Then you can delete the replaced one.
  3. Posts : 9,582
    Windows 8.1 Pro RTM x64
    Hi AVSIC and welcome to Windows 7 Forums
    Have a look at this Tutorial: https://www.sevenforums.com/tutorials...e-restore.html
  4. Posts : 14
    Windows 7 Pro
    The same happens...new shortcuts have the same sign...
  5. Posts : 17,796
    Try the suggestion given by Dwarf, sounds like it should work.
  6. Posts : 14
    Windows 7 Pro
    Thank you Dwarf, it worked! But, thank you ALL for your time!
    And sorry about my English...I am actually from Croatia :)
  7. Posts : 9,582
    You're welcome, AVSIC.
    P.S. I've moved your other query here: Document Icons
