Not sure how to describe this..HELP! Display Problem.
Page 3 of 4 FirstFirst 1234 LastLast
  1. Posts : 5,840
    Vista Ult64, Win7600
       #21
    Ok Just go into the Device Manager and click on your Display adapter, then right click your video card and click Uninstall and then press ok to confirm.
    And then repeat what you did as above.
  2. Posts : 11
       #22
    I'm not entirely sure what this means
    I uninstalled, and during reinstallation:
    Attached Thumbnails Attached Thumbnails Not sure how to describe this..HELP! Display Problem.-questionmark.jpg
  3. Posts : 5,840
       #23
    Ok turn off the PC and turn it back on
  4. Posts : 5,840
       #24
    Go to the driver file on your desktop that you downloaded and open it , click on properties and then install it in Compatibility Mode for vista.
    Compatibility Mode
  5. Posts : 11
       #25
    Ok, I've done exactly as you said, but the problem still persists ):
    What happens is
    -I uninstall the video card via device manager
    -Reboot [Sometimes it prompts me to, otherwise I do it manually]
    -After rebooting, it automatically detects and installs NVIDIA by itself, I'm not sure, but I think it's the 'plug and play' ?
    -It prompts to reboot again, if I choose to 'reboot later' and try to install the downloaded updated driver first, it will prompt me to reboot as well
    -Reboot again, [Plug and play NVIDIA installed; downloaded driver isn't] and the problem is still here
    -Install the downloaded driver, but there is no change.
    So basically, it's exactly as you've told me to do, except for the plug and play part, and I dunno how to stop it when its running, or disabling it, although I'm not sure if that'll help.
    Thanks.
  6. Posts : 5,840
       #26
    Sorry I had to go out for a while and will have to again in a few moments, in the meantime, try this program to get rid of your Driver, just follow the instructions, will talk to you later.
    Guru3D - Driver Sweeper
  7. Posts : 5,840
       #27
    What happens is
    Thanks.
    Hi, I'm back, If you haven't done anything with the program that I told you to look at, try this again,
    Ok this time Dont uninstall anything, and go to the folder on the desktop and try to install it in Compatibility Mode,
  8. Posts : 4,573
       #28
    Improper methodology detected.
    Use the official uninstaller(s) of the driver(s) you want to uninstall.
    Reboot your PC in Safe Mode.
    Run Driver Sweeper and select what to clean.
    Analyse lists all the entries possible to remove, cleaning removes the entries selected.
    More drivers can be selected for the same cleaning process.
  9. Posts : 5,840
       #29
    He's gone Walkabout again. Goodbye.
  10. Posts : 28,845
    Win 8 Release candidate 8400
       #30
    10-7 Jump
