Help with Power Supply
  1. Posts : 18
    win 7
    i need to get a power supply for my new pc i am building i need some help.
    CPU - i7 920
    Motherboard - GA-EX58-UD3R
    http://www.gigabyte.com/products/pro...px?pid=2989#ov
    Ram - 3 x 1GB DDR3
    GPU - GV-R583UD-1GD HD5830
    GV-R583UD-1GD - GIGABYTE
    PCIe - 650 ATI Tuner Card
    Drives - 6 x 1TB Hard Drive
    2 x DVD player
    This is the Power supply i have will it work or do i need to get a new one.
    XigmaTek NRP-MC651
    650w
    XIGMATEK
  2. Posts : 10,200
    PSU will work.
  3. Posts : 18
    win 7
    thx i started it and by my 4thx hard drive the pc will not power up it will power up for 1sec and go off then i have to turn off and on the power supply in the back before i can try agin can a hard drive create the problem or something else.
  4. Posts : 10,200
    I may be wrong. I had not paid close attention and didn't realize that you have six hard drives.
  5. Posts : 4,280
    I would suggest a 750w or better branded quality PSU. Your graphics card alone requires a 500w minimum add to that all your hard drives. Cpu and opticale drives, not to mention your heatsink fan and additional fans.
    Here's a link to a program that will help you get a general idea of what power supply you'll need, This is by no means definitive but you should always get more than required.
    Personally I consider the power supply as a very important core piece of hardware not to be skimped on. Hope this will help. Fabe http://extreme.outervision.com/psucalculatorlite.jsp
  6. Posts : 7,466
    DamDam remember more devices the more power you're going to need you have 6 hdd well hot diggity you're going to need more power that is some major business you got there i think a 750 or 850 watt would be enough could be wrong but i would go that high since you are running more then 2 hdd and also if your running a high end cpu and vidcard such as Nvidia product by all means GET MORE POWER
  7. Posts : 1,419
    Windows 7 7600 1 X64
    CPU - i7 920
    GA-EX58-UD3R (rev. 1.0) - GIGABYTE
    Ram - 3 x 1GB DDR3
    2 x DVD player
    XigmaTek NRP-MC651
    650w
    XIGMATEK
    6TB of Hard drives and only 3 gigs of memory is odd!
    You will need at least 850 watts of powere.
  8. Posts : 18
    win 7
    Update
    all is working know with my old Power Supply 650w i found out that 1 of my Hard Drive was caused the PS not to power up properly i did not know that a Hard drive can cause the Problem, i do have 6gigs of ram sorry posted wrong 3x2gig but i am still thinking of gating a new Power supply here is the one i have my eyes on.
    Corsair TX 850 Watt
    Antec Earthwatts 750W
    Corsair TX750W 750 Watt
  9. Posts : 2,963
    I'd get the 850w Corsair, or if money was an issue, the 750w Antec. I see no gain the 750w Corsair would give you over the other two. If you can afford it, definitely get a 850w power supply, as it would be more likely to work well.
  10. Posts : 1,965
    win 7 X64 Ultimate SP1
    PS
    Vist Asus.com -- They have a calculator all you do is fill in your devices and it will give you a wattage.
