Seagate Drive Problems???
I purchased 2 Seagate ST32000641AS drives. These are 2TB drives giving 4TB all up.
They are S.M.A.R.T enabled drives and as such I installed monitoring software to check up on them from time to time . I am concerned that both of these drives are showing indication of failure already. Normally I just use 1 program to check but I have tried with 3 different ones and they all show the health of both drives, one at 40% and the other at 32%.
One drive is showing Surface Read Error Rate at 80% health and Controller Hardware ECC Recovered at 32. The other drive is showing Surface Read Error Rate at 67%, Surface Seek error rate at 51%, and Controller Hardware ECC Recovered at 40%.
Have I got reason to be worried as these drives are only about 3 to 4 months in use. It is not showing any physical problem except that it is the slowest part of my PC rating at only 5.9 on the Windows Experience Test.
