PC won't power on OCZ PSU help ><
Page 1 of 5 123 ... LastLast
  1. Posts : 39
    Win 7 64bit
    I recently built a PC for my friend.
    Specs:
    Samsung 1TB Spinpoint F3 SATA II 7200RPM 32M
    OCZ ModXstream Pro 600W modular PSU
    LiteON IHAS324 SATA DVD-RW 24X Black Retail
    Microsoft Windows 7 Home Premium 64bit OEM
    Corsair CMX4GX3M2A1600C9 4GB (2x XMS3 2GB) PC-12800
    Tenda W322P Wireless N PCI Adapter
    Asus P7H55D-M EVO MB, Socket 1156, Intel H55 Chipset
    LG E2340V 23"W Slim LED HDMI FULL HD 5ms
    Intel Core i5 760 Processor LGA1156 2.8GHz 8MB Cache CPU
    NZXT Vulcan Micro ATX Case
    POV GTX 460 1G D5 2DVI/HDMI
    He wanted a good graphics card so he choose a lower range PSU
    I checked the specs for a GTX 460 and said minimum 550W PSU and the OCZ claimed it had SLI support and had the PCI-E adapter to fit it. And an extra 1 pin connected to one of the PCI-E cables for a bigger graphics card I assume.
    For the first couple days it was working but stutters such as the audio and video happened sometimes. He had to reset once in a game of starcraft 2 after the audio stutter. He said the video was kind of moving slow so maybe that was stuttering as well. So I came over and before I did anything he showed me a replay from starcraft 2. So it was working then.
    I thought I would reconnect the HD audio cable into motherboard as it is tightly fit against the graphics card and wireless PCI internet card. I then turned the PSU upside down so the fan is facing down so the cables would have a better reach and were more ordered, since it was kinda messy.
    Then I booted it up and it would go through the BIOS fine and start loading windows, the animation would go (win 7) and then it would hang and eventually power down. I put the Win 7 disc in thinking it may be because windows has a boot problem and it loaded up until it turned into the graphical screen and then hung. I tried the suggested windows recovery fix (forget the name, but the one after you power it down without shutting down) and it just hung again.
    So I then thought it could be the PSU. Since it had booted before I turned the PSU back with the fan facing up (not far from the graphics card) like it was originally and now it will not turn on.
    I am thinking that maybe the 600W wasn't enough to run the system or the PSU may be faulty. This was purchased about a week ago and it has warranty, what do you suggest?
    Thanks for reading,
  2. Posts : 8,375
    Welcome to the Seven Forums! Chooseyant
    I'm not seeing anything that require more then a 550w to 600w supply in the specs you provided. That only sees one main hard drive and a single optical drive along with the aveaage 4gb of memory, 1gb video card, and nothing else that would tax a good working supply.
    Since the supply is suspect and brand new the option to RMA the drive is wide open. The largest draw is generally during the intial startup going through the post tests followed by each new detection of hardwares as Windows loads. The supply may be lacking the needed regulation.
    As far as OCZ that had once been one of the better makes but seems to have slipped a bit quality wise. After running a 700w GameXtreme model for a good 3yrs. the new build saw a second spare supply in use for 2 weeks before it tripped a 20A wall outlet and took a new board along with it!
    That was an unused supply! You get a bad one every so often with any make while I elected to switch makes for the replacement board to follow. Don't change it with that supply if you have any doubts!
    The other things to look at would be a weak bios chip or weak cap on the board or something not installed correctly while the immediate shutdown being seen would most likely be a bad supply or problem on the board as an alternate source of the problems being seen.
    The last build here 3yrs. of age was seeing startup and immediate shutdowns until the second or third press on the power to finally see it startup normally. Or as it got worse it wouldn't even turn on! A replacement bios chip was located and waits for me to replace the board and have an assembler replace the bad chip with the new. Try a different supply to rule that out.
      My Computers
  3. Posts : 39
    Win 7 64bit
    Thanks a lot, yeah, I am going to test it with my PSU when I get it over. I really hope it isn't anything I've done to screw up the motherboard. I wouldn't think anything has damaged the caps on the front but it did take me awhile to fit it in to the brackets and since it is a small case maybe scratched the back a little.
  4. Posts : 39
    Win 7 64bit
    *UPDATE*
    I tried my PSU in it and it would load to windows 7 animation then hang.
    I then installed the original PSU in and it will now boot, but same thing.
    I even installed another graphics card I had on hand to make sure and same thing.
    Does this mean the motherboard is faulty? It is a brand new board and no damage whatsoever seems visible. My thoughts are to return it and then wait a month or some long duration to receive a new one and install it so my friend can finally have a working computer.
    RMA confuses me, I mean if they give you back a brand new product why can't the store give you a new one straight away and just restock the one they send back. In the past I've ended up just buying a new motherboard because I needed my computer, now, not 4 weeks.
  5. Posts : 8,375
    If you are dealing with a defective board sometimes the vendor will ship a replacement out to you before even sending the first back depending on whether you are a regular customer. That happened when helping out a friend who received 3 bad boards in a row being the same make and model.
    The vendor when contacted stated they likely had received a bad batch of boards at the time and the friend was advised to select a different model or go with a different make and model to get a new build running. Depending on where you order or buy from will depend on how the return and replacement takes to come in. Most are usually prompt once they get the bad board back in sending out a replacement.
    With a different supply and card tested for this it seems you were able to rule the supply out. With any new build the first thing to have a good working supply to avoid anything like seeing a new board cooked! That was a setback seen here in late spring.
    It's always a pain when your main system is down for any reason while the time and money on replacing hardwares is typically the worst. Hopefully the board is the only thing you will have to see replaced there.
      My Computers
  6. Posts : 39
    Win 7 64bit
    Thanks man
  7. Posts : 8,375
    You're welcome! I've been there a few times with setbacks. That's why I was hoping to have the old case onhand as a backup system as well as testing things there until the board let go "right when" how ironic the new case was first running! Wouldn't you know! "perfect timing"!
    Don't let it get to you! It's going to happen at some point anyways. Let's hope this is all you need for now however.
      My Computers
  8. Posts : 1,403
    Win 7 Ultimate 32bit
    To start troubleshooting this rather than just randomly sending parts back and forth.
    IF the mobo has on-board video (yes, doubtful) then I would start with the following.....
    If if yes, remove video card, otherwise leave it for now.
    Remove all stick of RAM except one
    Double check that all connections are in correctly, and make sure the CPU is seated properly
    Make sure that the thermal paste is set correctly on the CPU, I have seen some HeatSinks with thermal paste already one there and a plastic or wax covering to protect it and people not remove that cover before putting it on and securing it to the CPU.
    Then test it.
    But this sounds more like a heat issue than anything else.
  9. Posts : 8,375
    Since this is being seen with cold starts I doubt any temp problem is being seen. I had one board quite after the first few days on one build. Something simply let go!
    The board in the last case was acting up in a simliar fashion or the fan and lights blink and spin for a few seconds indicating the bios chip! Sure enough a board tester pointed right at it! A bad dimm typically still allows Windows to arrive at the desktop while things will tend to crash not keep hanging at the logo screen. But as part of the process of elimination a run of memtest can never hurt.
      My Computers
  10. Posts : 39
    Win 7 64bit
    Memtest has been done through the button on the board and clears fine.
