Well that's just part of the process of elimination. No bad supply, video card, or dimms to report. And since this is seen right when first powering up on a new build you don't have too many other things to look at besides the one other item not considered so far being the hard drive.
If the drive is bad from the start that cause a number of issues as well as a bad cap on the board. If you can get up to the desktop to run the "chkdsk /r" command at the Start>Run or a command prompt.
A simple right click on the drive's icon to open the Tools tab you can check off the two options there for automatically fixing any errors found in the event of bad sectors or not realizing a bad install of Windows had been seen. That's also one other possible cause for startup issues since you already swapped out video cards ruling out one set of drivers.
For the drive besides the chkdsk tool a diagnostics tool like HDTune to run that by or going to the Samsuang support site to see if they provide something there would test that idea. Other then those two you would be back looking at the board again.
