Keyboard Problem (Ctrl and Shift keys don't work correctly)
Hello everyone. Today my shift and ctrl keys stopped working correctly... it happened while I was playing and later when I tried to change the language using Alt + Shift. I checked if Sticky Keys and other similar options weren't turned on by accident, but they weren't.
And after some time spent in trying to fix the problem I opened the On-Screen Keyboard and noticed that when I use my Ctrl key, Shift is pressed automatically as well (it's just what On-Screen Keyboard says). The same thing happens when I press Shift, then the Ctrl key "presses itself". It so happens that all four (left and right shift, and left and right ctrl) keys are pressed at the same time, when I press just one of them.
Does everyone know where the problem could be from and how I can fix it... it's really annoying, I can't use any of the combinations like Ctrl + V, Ctrl + C, Ctrl + A, etc. The problem started while I was playing Assassin's Creed; I sometimes hear sounds like too-much-buttons-pressed while I play it, but I've never had this problem until today. I have no idea what it could be, I tried everything I know.
If it helps, the problem is still there while I chat or surf the web through Asus Express Gate, when the windows isn't running at all.
PS: Sorry if I used strange phrases or words, I am not a native English speaker.
