Keyboard Problem (Ctrl and Shift keys don't work correctly)
  1. Posts : 102
    Microsoft Windows 7 Ultimate x64 (Build 7601 SP1)
    Thanks for all suggestions, I will try another keyboard as soon as I can. It won't be a big surprise if the one I am using is the reason I'm having problems, for it is about six years old, it is my first and only (if we don't count the laptop) keyboard. I love it, and I love the fact I haven't had any problems with it until now. I am really used to typing on it, because six years isn't a short period of time.
    I will write when I fix the problem, thanks for everything... and if you think up something else, you are more than welcome.
  2. Posts : 8,608
    Windows 7 Ultimate 32bit SP1
       #12
    Have you rebooted since this key got stuck?
  3. Posts : 102
    Yes, I have... after I tried re-installing the drivers. Everything is fine now, it fixed itself while playing AC2 lol. I don't know how and why it happend.
    PS: How do I make the topic "solved"?
  4. Posts : 3,612
       #14
    well done ( i would still get a new keyboard now though )
  5. Posts : 3,612
       #15
    click the triangle at the top of page and type solved and a moderator will do the rest
  6. Posts : 102
       #16
    Thanks for everything. Now I know where to ask when I have problems with my PC.
  7. Posts : 3,612
       #17
    its my pleasure to help
  8. Posts : 1
    Windows 7 Enterprise 64bits
       #18
    I have exactly the same problem...
    The difference...i bought a new keyboard and i have exactly the same simptoms
    Any help besides buy another keyboard ?
  9. Posts : 3,612
       #19
    sorry to hear you have problems explain whats happening and what board you have :)
  10. Posts : 1
    MX-DIF
       #20
    nekov4ego said:
    Hello everyone. Today my shift and ctrl keys stopped working correctly... it happened while I was playing and later when I tried to change the language using Alt + Shift. I checked if Sticky Keys and other similar options weren't turned on by accident, but they weren't.
    And after some time spent in trying to fix the problem I opened the On-Screen Keyboard and noticed that when I use my Ctrl key, Shift is pressed automatically as well (it's just what On-Screen Keyboard says). The same thing happens when I press Shift, then the Ctrl key "presses itself". It so happens that all four (left and right shift, and left and right ctrl) keys are pressed at the same time, when I press just one of them.
    Does everyone know where the problem could be from and how I can fix it... it's really annoying, I can't use any of the combinations like Ctrl + V, Ctrl + C, Ctrl + A, etc. The problem started while I was playing Assassin's Creed; I sometimes hear sounds like too-much-buttons-pressed while I play it, but I've never had this problem until today. I have no idea what it could be, I tried everything I know.
    If it helps, the problem is still there while I chat or surf the web through Asus Express Gate, when the windows isn't running at all.
    PS: Sorry if I used strange phrases or words, I am not a native English speaker.
    Ok, I found this topic by google-search and I have the same problem and unable to fix it.
    I don't know how it started, I do not play any online-games but it happened nevertheless.
    I am using a Toshiba-laptop and I really don't know a thing about computers.
    I'm just about to throw the bloody thing through the window out of frustration.
    Apparently the solution from what I understood is replacing the keyboard, but since it's a laptop, I don't think that's possible right?
    Or should I reboot? How does that work? Won't I lose everything? I've never done that before and I'm scared I will lose everything.
    I'm absolutely desperate to fix this problem and to know how I can prevent it in the future.
