Help! plugged in, not charging.
  1. Posts : 688
    Windows 7 Ultimate 32-bit Service Pack 1
    karlsnooks said:
    Gordon,
    Go to the Dell website and download the manual for your laptop.
    Read the manual.
    This will answer some of your questions.
    I was on the Dell website and see the manual, but again was not helpful
  2. Posts : 654
    PooMan UK said:
    Have you tried doing this pal (it's a bit confusing, but it has worked for some laptops that I've come across with the same issues)
    01. Turn off laptop.
    02. Unplug AC power.
    03. Remove battery.
    04. Replace AC power.
    05. Turn on laptop, allow OS to boot.
    06. Once logged in to the machine, perform a normal shut down.
    07. Unplug AC power.
    08. Replace battery.
    09. Replace AC power.
    10. Turn on laptop, allow OS to boot. The battery should once again be charging as normal.
    Hope this helps
    +1 for these instructions
    Unless your power brick is damaged and not providing enough voltage. I would follow the above steps, if this dosent fix the problem i would borrow another power brick to confirm yours is faulty.
  3. Posts : 688
    Pusspa, how much is power brick ?
  4. Posts : 654
    I just replaced my old (dead) one for a generic one off eBay for $25AU
  5. Posts : 688
       #15
    Okay, because it doesn't have other solutions to fix the problem, probably or 95 % must buy new power brick. I tried very solutions but that is not helpful to fix the problem :S
  6. Posts : 660
    win7
       #16
    The point in the reading the article I pointed to in my earlier post was that this sort of situation has been reported on and investigated by Microsoft and they have given an explanation of why the problem occurs. They have also explained why the symptoms were not seen using XP...its well worth the read. The upshot is , that if your system is reporting that you should consider replacing your battery, you would be advised to take the advice. Sorry for the bad news , but thats the advice....
  7. Posts : 25
    Windows 7 Ultimate 64bits
       #17
    Can't you take a simple voltage meter,cost around € 7,-, and check if and how much Volt there is at either end.?
  8. Posts : 163
    Go to device manager and expand batteries. Right click Microsoft ACPI-Compliant Control Method Battery and uninstall it. Then reboot your laptop(it will automatically reinstall the driver) and hopefully it will say it is charging.
  9. Posts : 688
       #19
    Yes i know for this solution, i tried it but it doesn't charge again. Probably the battery is very damaged.
  10. Posts : 688
       #20
    Oh... You think that is about a voltage problem?
