Windows 7: (Code 24) - Power Controll Error - Help
28 Nov 2010   #1
Steven511
Windows 7 Home Premium (x64) (build 7600)
Hey all, I have this problem and get this
"This device is not present, is not working properly, or does not have all its drivers installed. (Code 24)"
I tryed going to drivers and it says under "Current Status" saysStatus: Stoped and I try clicking Start but gives me yet another Error - "The system encountered the following error while attempting to start the service - The system cannot find the file specified"
any help welcome, my power supply is - Antec true power quattro 1200 watt
Thanks in advance all.
28 Nov 2010   #2
Lemur
Take a look in Device Manager and see if your device is listed. Do you know what device the message is referring to?
28 Nov 2010   #3
Steven511
Thanks for the reply and yes it shows up in device manager but has the triangle with the ! in it and next to the Power Controll
Edit - Oh and its with in the device manager as in "None-Plug and Play Drivers"
28 Nov 2010   #4
Lemur
Can you provide a screen capture of this?
(oh, and it's "non-plug and play", but not a big deal at all)
28 Nov 2010   #5
Steven511
Here
29 Nov 2010   #6
Lemur
Are you running cyberlink powerdvd?
29 Nov 2010   #7
Steven511
CyberLink Blu-Ray
30 Nov 2010   #8
Lemur
I think if you uninstall this program, the problem may resolve itself. If it does, there are alternatives to play blu ray.
01 Dec 2010   #9
Steven511
ye I have reinstalled windows and it has seem to have gone
Windows Update Error, Error Code 80070643, Code 9C57
Computer model: Panasonic Toughbook CF-31 OS: Windows 7 SP1 Processor: Intel Core i5-2540M CPU @ 2.60GHz 2.60GHz RAM: 4 GB (3.89 GB usable) System type: 64-bit CBS Log CBS.zip - Google Drive I ran the SURT tool Windows6.1-KB947821-v34-x64.msu.
Windows Updates & Activation
Error code = 0x490 due to power cut, now Windows completely missing!
Hello everyone, I have a problem I attempted to solve by following a tutorial but was unsuccesful. My computer was installing windows updates when the power went out. From that moment, when restarted, it offer me a choice of 1. attempting startup repair 2. loading windows as if nothing...
Installation & Setup
Error Code 41 - Kernel Power Failure
Hello I was wondering if anyone could help me or if anyone has similar issues? I've been plagued with random restarts from error code 41 - kernel power failure for weeks. Please don't send me off to the microsoft knowledgebase, that doesn't tell me Jack! especially with the bug check code of...
BSOD Help and Support
fan controll
here is my prob i cleand all dust out and temp are still a little high speedfan dosent support my chipset or cpu of anything so........ can any body help me get my fan to stay on full blast i dont care about battery life here are my spec..... ican put more up of what ever just let me know what u...
General Discussion
Win7 Firewall won't turn on error code 0x6D9 and error code 0x80070424
Ok - I'm trying to fix my friends' computer - Toshiba Satellite L455-S5975 running Windows 7 32-bit Windows firewall is off and I need to "Update Firewall Settings". When I click use recommended settings, I get a message that says it "can't change some of your settings. Error code 0x80070424" I...
System Security
