rtl8187, wireless problem
Page 3 of 3 FirstFirst 123
  1. Posts : 13
    windows 7 32 bit
       #21
    simzy said:
    kword88 said:
    simzy said:
    The Marvell Yukon 88e8056 is listed but not the RTL8187
    and this is after uninstalling/restarting?
    no, thought it would be a god idea to se what you said first:) i'll uninstall now!
    did that, but same problem, wnidows just says : the driver for RTL8187_wireless is not installed. Install the latest driver for the device should i try to reinstall one of the drivers i've downloaded? or would it be an idea to remove every single file i had befor i installed win 7?
  2. Posts : 13
    windows 7 32 bit
       #22
    anyone?
