Any other ideas folks. Pin 10 might be diff on my tv lol.
NO. But you do have to tell your TV which input is being used. Example, if your TV has 3 HDMI inputs and you plug into HDMI port number 2, then thru the TV menu you would select HDMI #2
The best way to connect is thru HDMI, then DVI, depending on what connector your graphics card has. If you connect thru VGA your resolution on the TV may be limited.
Good news, enjoy! films look excellent as do games,i use 32" samsung as monitor, be careful of ghosting or "screenburn"
