My HDTV Used As Monitor Problem
Page 2 of 2 FirstFirst 12
  1. Posts : 617
    Windows 7 64Bit Ultimate Edition SP1
    Any other ideas folks. Pin 10 might be diff on my tv lol.
  2. Posts : 617
       #12
    Do i have to tell my pc to out via the GPU, do i have to enable something on my pc etc????
  3. Posts : 67
    Win 7 32bit HP
    NO. But you do have to tell your TV which input is being used. Example, if your TV has 3 HDMI inputs and you plug into HDMI port number 2, then thru the TV menu you would select HDMI #2
    The best way to connect is thru HDMI, then DVI, depending on what connector your graphics card has. If you connect thru VGA your resolution on the TV may be limited.
  4. Posts : 617
       #14
    I have now just got my original monitor connected, i have my 32 inch LG 1080p HDTV connected to my HDMI slot on my GEFORCE PALIT GTX 460 1GB and the LG is on the right channel and it is still not showing my pc, my pc has detected the LG though.
  5. Posts : 67
    Win 7 32bit HP
       #15
    rmw020 said:
    I have now just got my original monitor connected, i have my 32 inch LG 1080p HDTV conected to my HDMI slot on my GEFORCE PALIT GTX 460 1GB and the LG is on the right channel and it is still not showing my pc, my pc has detected the LG though.
    The instruction manual for my TV states that (in the US) you should set the PC refresh rate to 60Hz before connecting to the TV.
    Also have you checked the troubleshooting section of your manual?
    Attached Thumbnails Attached Thumbnails My HDTV Used As Monitor Problem-scan0006.jpg
  6. Posts : 617
       #16
    I got it sorted folks. Thanks for all the help. Happy New Year.
  7. Posts : 14,606
       #17
    Let me guess, you got the correct cable sorted out?
  8. Posts : 617
       #18
    Was to do with Resolution lol, or it was a better cable.
  9. Posts : 14,606
       #19
    Good news, enjoy! films look excellent as do games,i use 32" samsung as monitor, be careful of ghosting or "screenburn"
