Possible ram problem?
Page 1 of 3 123 LastLast
  1. Posts : 1,117
    Se7en X64 ultimate/Se7en X64 ultimate
    hey guys! I recently bought 4X 1GB 400Mhz PC3200 crucial tech ram sticks and it is showing in CPU-Z running at 200Mhz!! (pic included) and I had some old ones before that and they too showed running at 200Mhz which is why I bought the new ram, is there something wrong with my board? or is it normal?
    comp specs: HP Media Center m1270n and I have windows se7en 32Bit 3.0Ghz cpu
    is there some sort of settings I have to make in the bios? I've looked and I can't see anything that pertains to the ram frequency settings what could be wrong? thanks
    Attached Thumbnails Attached Thumbnails Possible ram problem?-cpu-z-capture.png   Possible ram problem?-cpu-z-capture2.png
  2. Posts : 12,012
    I do believe that is normal. It's "DDR" memory, which stands for Double Data Rate. So you have to double the number. 200 x 2 = 400.
    Double data rate - Wikipedia, the free encyclopedia
  3. Posts : 1,127
    Win7U 64 RTM
    Are your system specs correct?
    Ok, OK ...I missed your system info posted inline, but from what I can tell, you're running in single channel when your system supports dual channel, as per this link (and a few others):
    http://www.memorystock.com/memory/He...term1270n.html
    and here:
    http://www.crucial.com/eu/upgrade/co...270n/list.html
    From which this screen shot is taken:
    The fact that you're running in single channel (as per your CPUz screenshot) means either that you're using the wrong RAM or it's somehow the wrong config.
    James
  4. Posts : 6,349
    PassMark RAMMon - Identify RAM type, speed & memory timings
    Download and install the above. Right side of page. Click Green "Download 32bit."
    Best RAM specification info software.
    Mike
    Also ignatz is correct. You double the 200 DRAM which is doubled by FSB to 400MHz. FSB- Front Side Bus
  5. Posts : 6,349
    James Colbert
    His posting is a different computer than spec PC. HP Media Center m1270n
    Which is here.
    http://h10025.www1.hp.com/ewfrf/wc/d...product=443756
    Mike
      • Four 184-pin DDR DIMM sockets
      • Supports PC3200 (400 MHz) PC2700 (333 MHz) DDR DIMM type
      • Maximum HP/Compaq approved memory is 4 GB*
  6. Posts : 6,879
    Win 7 Ultimate x64
    James it isn't the system in his specs but this one,
  7. Posts : 1,117
    Hopalong X said:
    James Colbert
    Which is here.
    Product information HP Media Center m1270n Desktop PC - HP Customer Care (United States - English)
    Mike
    that is correct, ok so then its normal?
  8. Posts : 6,349
    Yep. Just fine.
    Mike
  9. Posts : 1,117
    wow that RAMmon is PERCISE AND DETIALED!!! but look in the red rectangle I did it shows 200Mhz too! also my ram in my specs only shows 2.75 out of the 4gb and its buggin the sh*t outta me! LOL but I know I cant do nothing about it! GGRRR
    Attached Thumbnails Attached Thumbnails Possible ram problem?-rammon-capture.png
  10. Posts : 1,127
    Win7U 64 RTM
    Yes, I did miss that, but was busy correcting myself when you posted. But still, my investigation shows that the m1270n should be running in dual channel. You likely have seen my corrected post by now.
    Link here:
