Using power supply outside of computer
Page 1 of 3 123 LastLast
  1. Posts : 67
    Win 7 32bit HP
    I want to use a spare power supply outside of the computer, does anyone know how to get it working since it's not connected to a motherboard?
  2. Posts : 752
    Windows
    Hello there, Here:
    Info: Can I use two Power supplies with one computer?? - Overclock.net - Overclocking.net
    Although i would NOT recommend it.. i'd rather have one GOOD PSU than 2 PSUs and probably busting up a 2k$ PC
  3. Posts : 67
    Win 7 32bit HP
    Punkster said:
    Hello there, Here:
    My power supply will in no way be connected to a computer. I have a cable that has a IDE/SATA connection on one end and USB on the other, I want to look at the contents of some old hard drives without opening my computer and using one of it's power cables.
  4. Posts : 2,344
    Use a Piece of wire or straightened paper clip to connect the Green wire on the 24 pin plug to any of the black ones
  5. Posts : 67
    Win 7 32bit HP
    I'll give it a try, thanks
  6. Posts : 6,618
    Instead of the wire, connect that to spare motherboard and RAM, and you have a great testbed for components...at least for video cards or fans
  7. Posts : 11,408
    ME/XP/Vista/Win7
  8. Posts : 6,618
    theog said:
    Yes, I would have said that, except that a wire is cheaper.
  9. Posts : 11,408
    ME/XP/Vista/Win7
    seekermeister said:
    But not SAFE.
  10. Posts : 6,618
    I'm not sure what you mean by not safe, because it is only 12 volts and isn't going to shock anyone. As far as it shorting out to something else, that could be prevented by using an insulated wire.
