battery not charging more then 91 %
  1. Posts : 3
    Windows 7 Ultimate 64 bit
    I have acer aspire 5551 , my laptop battery doesnt charges more then 91 % , what are the possible solutions for it ?
  2. NoN
    Welcome to Sevenforums,
    You might want to fully drain the battery before, then plug it again on wire powered to let it charge 100%.
    You can drain it faster if you're on a switchable graphics system by choosing the ATI Performance.
    To evaluate to battery performance you can follow this tutorial:
    Power Efficiency Diagnostics Report[2]=Power Management
  3. Posts : 5,795
    See if your laptop has a conditioning utility in it. Older HP laptops used to let you hit F6 or something like that as they booted, and it would bring you to a battery utility that would drain the battery completely, and perform a full charge.
  4. Posts : 3
    the laptop get drained fully , but the charging does not get more then 91 % , even if it is plugged for several hours , it keep on charging and still remains on 91 %
  5. Posts : 7,878
    You could potentially have a cell going bad in the battery itself? Have you noticed that the life of the laptop dropping significantly or had it get down to 20% and the laptop just shut off without warning?
  6. Posts : 3
    yes battery life has got down , what can be da possible solution for it ?
  7. Posts : 1,114
    Windows 7 Home Premium 64 bit
    Maybe get ready to buy a new battery, use the old one till it won't charge anymore
  8. NoN
    It can be the fact your using the battery often, but don't let it drain enough then plug it again. Could be bad Power Plan management also.
    There's a way i think to reset the memory of the Li-ion battery (if it had retain the last charge). Gonna try to find back that one.
    Meanwhile try to manage your Power Plan settings.
    Power Plan - Select[2]=Power Management
    Windows 7 battery (Consider replacing)
    "Consider Replacing Your Battery"
  9. Posts : 7,878
    Buy a new battery. Typically a "high quality" lithium ion battery will last 2-3 years. A cheapo lithium ion battery will last 9-18 months.
    My wife's HP battery did something similar at about 1 year. I replaced it and it's working great now.
  10. Posts : 28
    I am having the same issue with my nephew's Acer 5741-A. He's only had it since Christmas, but now it won't charge past 89% - the orange light stays on forever and never goes blue (which indicates fully charged). PParks said that a cheap battery doesn't last long - so do they usually ship cheap batteries with laptops and how much would a quality one cost, that would last for 2-3 years?
    He has been using it while plugged in a lot, but surely that should just reduce the battery life, not cause the charging light to stop working properly?
