Card reader problem
  1. Posts : 3
    windows 7 64 bit home premium
    Card reader problem
    Hello all. I could really use some help. When I plug a CF card into either my internal or external cad readers nothing happens. If I unplug the external reader from the USB and plug it back in it will read the card. Soon as I try to put another card in the reader same thing happens and I need to unplug and replug external reader into USB port Internal only reads card after I reboot the computer but same problem remove one card for another and the same thing happens. I am using windows 7 64 bit and numerous types of USB card readers all with current drivers. all cards are 8gb and all readers are high capacity readers. Thanks in advance.
  2. Lee
    Win 7 Pro x64, VM Win XP, Win7 Pro Sandbox, Kubuntu 11
    Hi fdnavy, and Welcome to the Seven Forums. . .
    Sounds like a driver problem. Go to the manufacture's site and see if they have update the drivers for your specific card reader. Good luck
  3. Posts : 3
    Thanks. I have already upgraded all of the drivers. What else could it be?
  4. Posts : 67
    Win 7 32bit HP
    Is this card reader compatiable with 64 bit?
  5. Posts : 3
    Yes both readers are 64 bit compatable. One is an internal USB rose will 40 in 1 drive the other is an external USB lexar reader. Both have current drivers. It seems like the readers themselves are unmounting because if I unplug and replug it will work until the next card swap.
  6. Posts : 67
    Win 7 32bit HP
    Have you tried the external reader in another computer? Try another USB port on your machine, do you have all USB ports occupied? Maybe it's a power issue. I've had an external HD work on one port but not another.
    Have you tried the Hardware and Devices troubleshooter ?
