hard drive problem
  1. Posts : 2
    windows 7 profesional x32
    hard drive problem
    im running 2 hard drives on my pc. a 500gig and a 1 terabyte. i was running my pc with only the 500 gig then added the tera. im trying to remove the 500 gig to make it a portable but every time i remove it my pc refuse to boot windows. when i re enter into the pc it starts up. plllllllzzzzzzzzz help. i saw though that there is only a system reserve on the 500gig. might that cause the problem???
  2. Posts : 1,872
    Windows 10 Pro x64, Windows 8.1 Pro x64, Windows 7 Ultimate x64 SP1,
    Yes, the system reserve is where the boot files are. You can remove the 500GB drive and boot using the Windows 7 DVD and select repair. It should then install the boot files on the Terabyte drive. There will not be a system reserve partition however, since it will install the boot files directly to the C: drive.
  3. Posts : 2
    do i need to do a special setup for instance do i need to make the tera my primary master or something
  4. Posts : 1,872
    After you do the repair. Then reconnect the 500GB drive and go into the BIOS and make sure the 2TB drive is the first drive in the boot order.
