Windows 7: System drive problem (maybe ?)
15 Feb 2011   #11
nitromad
windows 7 64bit
hi all
defrag making things worse sounds right as number of times the drive gone missing from "my computer" and defrag screen and check disk had to be used to get it back
my second harddrive is fine :S also i tryed diffent ports but got boot file missing.
anyways thanks for the help so far
gavin
15 Feb 2011   #12
nitromad
windows 7 64bit
hi all
ok so........ harddrive dead ???? or ???????
im really at an lost
thanks
gavin
15 Feb 2011   #13
Bill2
Hmm....that looks definitely destroyed. Good, i mean now we know its bad. But run the tests with the samsung utility too.
HD502HJ 3.5" SATA HDD - HD502HJ - 3.5 SATA HDD - Hard Disk Drive | SAMSUNG
15 Feb 2011   #14
nitromad
windows 7 64bit
Quote   Quote: Originally Posted by Bill2 View Post
Hi
the samsung boot cd does not find any drives !! yet windows boots just so so slow
my 4 year old laptop runs faster !!
no more nfts or disk errors in event viewer.
i ran 8 hours of memtest 86+ with no errors, im really lost to point of shelfing the new build
thanks all
gavin
ps look at this odd results !
15 Feb 2011   #15
Maguscreed
Windows 7 x64
Everything here points to the drive being bad. If you are still under warranty I would back up what is still good on there do a basic wipe, then set up a RMA with the manufacturer.
15 Feb 2011   #16
nitromad
windows 7 64bit
Hi
ok this getting silly this is screen shots of my other drive (1TB)
have both gone south ? (bad).
any other idea on how to check before i RMA the 500gb ? (1TB) out of warritiy
thanks
gavin
System drive problem (maybe ?)-15-february-2011_18-16.png System drive problem (maybe ?)-15-february-2011_18-17.png
15 Feb 2011   #17
Maguscreed
Windows 7 x64
Actually may want to hold on that rma.
I have to admit I've never seen this before. The odds that both drives have decided to go bad at the same time are really low though.
Is it possible that you have a friend's computer or another yourself you could plug one of these drives into and run the same test on?
I'm beginning to think my initial impression of a bad motherboard controller may have been correct.
15 Feb 2011   #18
nitromad
windows 7 64bit
ive still got my old pc these drives came out of i hook it up and post back !
thanks
gavin
15 Feb 2011   #19
1Bowtie
Windows 7 Home Premium 64 bit
Is this store bought or self built, next you said os only week old, did you upgrade or clean install, the motherboard is still possibility but i'm leaning first to bad install of os, just a thought.
15 Feb 2011   #20
nitromad
windows 7 64bit
Hi
i built it and hard drive was formatted as followed by an page from this site before an clean install on windows 7 64bit was installed.
thanks
gavin
found the page
SSD / HDD : Optimize for Windows Reinstallation
Problem with System Restore - usb drive not recognised
So I have been trying to sort this out all day to no joy. I have a system restore image on an external hard drive and was sent a replacement hard drive for by dell. I got to the point of restoring from the system image, however when I reboot to continue I cannot select the external drive or see...
Backup and Restore
Create system image - what constitues a system drive?
I have an old PC with a fairly small (and almost full) SSD C drive and a couple of HDDs. When running a "Create a system image" backup, both the C and D drives are flagged as "system" and are automatically marked as being included in the backup. That was not the case on another PC. I see...
Backup and Restore
Startup Problem - Start up Loop - c drive is system reserved
Hi, I have been breaking my head with win 7 startup, which keeps going into loops. Initially I got the captioned error " C drive is system reserved" with very little space in my c drive. I checked information and repaired C drive using diskpart . I can access the c drive contents through command...
Hardware & Devices
Help! Problem with system restore and SMART Hard Drive detection
Hi, I have a Dell XPS laptop which for whatever reason decided one day not to boot. I took the opportunity to do a backup and full restore using Dell DataSafe (?) which crashed and got stuck at 29%. On attempting to restart my computer I receive an error message from SMART that my hard drive...
Backup and Restore
System reserved partition (system, active) on Slave drive
Current Master Drive (C:) : OCZ-VERT EX2 SCSI (my SATA Drive) - 60 GB Current Slave Drive (D:) : WDC WD10EARS-00Y5B1 ATA - 1 TB My computer used to have a boot file set on my slave drive, but OS installed on my master. So i eventually reformatted it so that my boot AND OS was installed on my...
General Discussion
