battery problem
  1. Posts : 133
    windows7
    battery problem
    I have a laptop. i install windows7 in it. aafter insatlling it, i have a problem in my Power plan.
    my PC is turn off after running on battery.
    a blank screen displays and then turning off.
    how can i correcti it?
  2. Posts : 932
    Hi maifs welcome to SF, can you give use the Make and Model of your laptop and fill out your System Specs in your UserCP so we can help you out more.
    Also do you have the latest firmware on your laptop for BIOS and all updated drivers and windows updates?
  3. Posts : 28,845
    Win 8 Release candidate 8400
    power plans
    Hi and welcome to SF
    First thing is we need to know all about your computer and OS.
    Waitinf for your info
    Ken
  4. Posts : 133
    windows7
    my OS is Windows7 and pc is a Gericom Humer Advance 2640 DVD+RW.
    16bit soundblaster pro competible + AC 97 CODEC , Micro, Stereo Speakers ,
    smart Li-Ion 6 cells or 8 cells (4000 mAh)
  5. Posts : 28,845
    battery problem
    Are you complaining about a shutdown problem or a battery problem?
    Ken
  6. Posts : 133
    windows7
    Ken
    shutdown problem not battery problem.
  7. Posts : 28,845
    shutdown
    what version of win 7?
    Ken
  8. Posts : 133
    windows7
    7100.0.090421-1700_x86fre_client_en-us_retail_ultimate-grc1culfrer_en_dvd
    this one
  9. Posts : 28,845
    shutdiwn problem
    this one
    At this point it might just be easier to upgrade to the most recent build its 7260 (32 bit) and it might cure uour porblem
    Ken
  10. Posts : 133
    windows7
    i upload all my system specifications.
    you may check it.
    if you can then help me.
