install hp multi function
Hi, I have a hp multi function hooked up to a win7pc by usb connection, I also have a laserjet hooked up to my ethernet lan. I am trying to install a hp 3310 with a ethernet connection. The latest win7 hp software gets almost to the end of the install routine until it asks how I want to connect it. I choose ethernet and it checks whatever, it shows my 3310 connections correctly and then tells me it cant connect. Win7 add a device cant find it. I can ping the unit ok, and I can connect to it through the ip address, and i can scan through the browser. If i go to win7s add a printer it installs a basic print driver and allows me to print as normal. All other xp pcs on the lan can print to it.
I would dearly love to use the scanner on the 3310.
By the way the 3310 worked with all functions when it was connected via usb to a xp pc. any ideas?
