Help-Hard Drive question/about partioning
  1. blu
    windows 7 home premium 32 bit
    i made 2 partions ..for dual booting windows 7 and linux -
    Hard drive is NTFS
    i already deleted the linux partion .
    now it's showing up as free space 100 gigs.
    how can i shrink it ? and put it back to my C drive if at all possible?
  2. Posts : 33
    Windows 7 Ultimate 64bit
    I believe this Tutorial is what you are looking for.
    Partition or Volume - Extend
  3. Posts : 9,606
    Download Partition Wizard (Free Version). Make a bootable CD, then boot from it to access your HD & chang, delete, expand partitions as needed.
    Free Download Magic Partition Manager Software - Partition Wizard Online
    Tutorial Partition Wizard : Use the Bootable CD
  4. blu
    THANK YOU. you have solved my problem! after spending about 4 hours somebody finally showed me.
    i could kiss you man.
