Is my power supply dead?
  1. Posts : 89
    Windows 7 Ultimate 64-bit
    Normally the power button on my computer is lit up blue when the computer is on and it slowly flashes blue when it is asleep. I tried to turn on my computer today and the power button is more quickly flashing yellow and I do not hear the power supply. I purchased this COOLER MASTER GX Series RS650-ACAAE3-US 650W ATX12V v2.31 80 PLUS Certified Active PFC Power Supply over a year ago. It is plugged in and the switch is to the on position. Has it died?
  2. Posts : 11,424
    XGamer95,
    It's a good guess but only that. I would open and inspect all connections, blow out PSU and case completely, while case side is open I would watch and listen as you start up. Then get back to us with any error lights on mobo, sounds and the like. Can you find a friend with, beg, steal or borrow another PSU?
  3. Posts : 1,794
    MS Windows 8
    linnemeyerhere could be right, have a look at this.
    Dell Power Button Lights | PCTechBytes
  4. Posts : 89
    Fortunately, my computer started working again when I turned the power supply's switch back to the On position. I guess it just needed a break :P Even though it fixed itself, I appreciate and thank you for the great respones :) The article about the lights was accurate for my computer and luckily I kept my old power supply incase I ever need to test it.
  5. Posts : 1,794
    MS Windows 8
    yeah i know, i am using dell too. glad you got it working! :)
  6. Posts : 11,424
    I love problems that just work themselves out !
  7. Posts : 3,187
    For future reference, some power supplies seem to need a full switch-off to reset themselves if they have a glitch. My secondary computer is like that. If the power blinks I have to turn the PSU off, count to three, then all is well when I turn it back on.
    Glad you got it going again. :)
  8. Posts : 11,424
    Just like resetting a modem and or wireless router. Unplug, count to 30 then replug the devices in the logical order which the signal runs allowing each device to warm up and run though it's complete cycle before plugging the next in and so on.
    Wireless devices like keyboards and mice, remove batteries then hit keys and or buttons pressing for 30 seconds, then replace batteries (fully charged or new) then turn on and then go threw any sync process. Discharging internal charges takes time and is well worth the extra times when quick on/off's aren't doing the job !
