Windows 7: Noobish Question about Hardware Parts
20 Jul 2009   #31
Antman
Oosa is such a great country. I am not recommending Dell, just referencing a good deal.
20 Jul 2009   #32
Sope
Windows 7 64-bit
Quote   Quote: Originally Posted by pparks1 View Post
..........I don't forsee a need to replace a CPU like a Q9550 in the next 3 years given how powerful of a CPU it is.........
Here is a quick list of some parts that I put together stateside for just about $800 even...you can use it as a reference.....
Total ~$823
That's a great help!
Gives me a good basis and some ideas to work from.
Unfortunately the equivalent list of parts from a good value online supplier in the UK comes to £666 which is $1100
Looks like going for Core 2 Duo would maybe knock about £100 ($165) off that which would bring it closer to the mark.
Could get away with a smaller HDD but that wouldn't make a great deal of difference.
Hmm....needs some more consideration. Not sure whether I'll be building it before or after Christmas (I've already sorted my pre-order copy of Windows 7 !) so maybe by then the exchange rates will have improved or there will be some better deals about.....maybe
Thanks for your time, I'm sure I'll be coming back with more questions in the near future.
Cheers.
20 Jul 2009   #33
Sope
Windows 7 64-bit
Quote   Quote: Originally Posted by Antman View Post
Yeah...this is the sort of thing that's available in the UK
http://www.ebuyer.com/product/167291
http://www.ebuyer.com/product/167292
20 Jul 2009   #34
Sope
Windows 7 64-bit
I've also considered this AMD Phenom 9500 2.2GHz Quad Core, 4GB RAM, 640GB HDD, DVDRW, Card Reader, nVidia GTS250, NO OS (£400=$660)
Main disadvantage I can see is there's no option to add more RAM and probably some of the basic components are lacking in quality.
Suppose it depends how quickly it will become outdated....but if it lasted 2yrs+?
I would much prefer to have a go at building my own system but sadly cost and value for money are factors that have to be taken into account.
20 Jul 2009   #35
pparks1
Your other option would also to be knocking down the case just a little bit. That Antec 900 is a bit expensive, you can get an Antec 300 for about 50-60% the cost.
And if you have time to wait, the prices and the power levels are simply going to increase...that's the way that it always is.
21 Jul 2009   #36
Sope
Windows 7 64-bit
Antec 300 looks good (certainly is popular).
I notice Corsair do a 450W HX Modular PSU in UK (not available in N&S America) which is 30% cheaper than the 520W, and with 7yr warranty. I'm guessing this would probably be enough for my needs? (I don't foresee me going for SLI or adding a stack of extra drives)
I could also knock the cost down a bit if I go for a 500GB 16MB cache HDD.
I'm concerned I may regret going for a dual core rather than a quad CPU looking ahead (I believe most games at the moment still only utilize 2 cores but I guess that will change in the near future?).
I'm still keen to do a self build which I'm now doubting will save me much cash but I'll be getting better components, more options to upgrade in the future and more satisfaction.
I can wait a few more months, and in the meantime keep an eye out for discounts too.
Thanks for all the advice, much appreciated.
21 Jul 2009   #37
HerrKaLeun
W7 Pro 64
I have a dual-core at 3.5 GHz and it is fast enought for me. But most of my applications (Matlab, energy simulations) iterate and are single threaded by nature.
I see that when the virusscan works, defragmenting etc. both cores are used. So I think in real life (and W7 certainly does a good job using multiple cores) a quad is good. Especially for games assuming you still run something else (firewall, bittorrent, borwoser, antivir etc.). In the future more software will be multi-core.
My case probably is rare with single threaded applications, MP3 video... all is multi-core. Even with single -threaded applications W7 uses multiple cores better. I talked to the Trane Trace support and they said Vista is 20% faster than XP with their software jsut because the traskmamanger (or whatever) uses multiple cores better in single threaded application. future OS probably will even improve that part.
21 Jul 2009   #38
Antman
Quote   Quote: Originally Posted by Sope View Post
Those are C2D w/DDR2. I linked to i7 w / DDR3. Not the same.
21 Jul 2009   #39
Sope
Windows 7 64-bit
Understood, although I was actually trying to show what is available in UK relative to my price range - sadly (for me) US prices are much better than UK
21 Jul 2009   #40
Sope
Windows 7 64-bit
Out of interest I've just gone and looked for that Dell PC from a discount UK website, I couldn't find an exact match but something very close (i believe) here is priced at £769 which is $1266 US
Still prefer to build my own though, but it shows it's going to be more difficult than I thought to beat some pre-built systems on price v spec.
Where can I buy hardware in the UK and not get faulty parts?
Hello, I'm CrazyKilla America is a giant place and full of technology and I'm guessing that no one has problems finding their hardware, but here in the tiny UK I don't know who I can trust, I have bought almost all of my hardware from Amazon.co.uk, but this site isn't made for selling hardware...
Hardware & Devices
laptop replacement parts question
my laptop's touchpad currently go crazy when im controlling it what do you think is it faulty that i have to replace it or its just my system os, already tried restarting and system restore what website can i buy this replacement parts and about how much range is this touchpad my laptop is...
Hardware & Devices
Thermal Paste Question..(Noobish Question)
Hey guys, I recently purchased Corsair H40 that came with pre applied thermal paste. Before I placed the H40 sink on my processor, I applied a thin layer on the on the processor with Cooler Master thermal paste. So essentially I mixed the H40 pre applied thermal paste with the Cooler Master thermal...
PC Custom Builds and Overclocking
Hardware Question
I play The Sims™3 like crazy! I love the game and can never stop playing it. Unfortunately, my PC doesn't like it very well, as it seems, because the one widget I have on my desktop shows the CPU and Physical Memory readings. After the Memory gets to a certain point either over 80 or 90, the entire...
Hardware & Devices
2 noobish questions
1 how many post do you need to be able to send messages? 2 is there a xp forum? I loved the vista forum...
Chillout Room
