Help plz ,, problem with diskpart
  1. Posts : 9
    Hi
    i want ur help plz >
    i have sony vaio usb flash disk 16GB ..
    i have play with disk part trying to format it and making new partition ,
    but i do not know what happen ,, now the flash is with size 189 mb .
    i try to clean it from diskpart but i can't i have this mesage "diskpart has encountered an error the media is write protected "
    i try many sol in the web but now one helped me >>
    help plz
    thanks
  2. Posts : 4,198
    Windows 10 Pro
    Why are you trying to format USB Flash Drive with diskpart? Just plug it and quick format it by right-clicking on the USB Drive in My Computer :)
  3. Posts : 9
    now i can't
    its appear that the disk write protected and the size appear 198 mb and its orignal size 16 gb !!
  4. Posts : 10,994
    Win 7 Pro 64-bit
    Don't forget to check if your flash drive has a write protect switch (to keep data from accidentally being erased.) If it has such a switch it needs to be off.
  5. Posts : 5,056
    Try the attrib command from diskpart, as explained here (makes sure you read the first comment as well).
    Windows 7 RC0 disk is write protected | EnX Blog
    If that doesnt help, try this method.
    Remove Write Protection On USB Pen Drive or Memory Card or iPod
    If that too doesnt work, try a 3rd party utility - HP format tool.
    Download HP USB Disk Storage Format Tool 2.2.3 Free - Windows-based Format Utility for HP Drive Key or DiskOnKey USB Device - Softpedia
  6. Posts : 9
    Thank you all >>
    I tried all the ways but my problem still >>
  7. Posts : 5,056
    Well, try running chkdsk on the flash drive.
    Where did you buy this stick from and what were you doing after which the problem arose?
  8. Posts : 9
    chkdsk does not work for fat >>>
    i tried to clean the flash but i can not clean it >>
  9. Posts : 9
    up >>
    help plz
  10. Posts : 5,056
    This one looks a lost cause. Try this tool anyway.
    Check Flash Review - Check Flash Download - Softpedia
