PSU or UPS Problem? HELP!
Page 1 of 3 123 LastLast
  1. Posts : 4,198
    Windows 10 Pro
    Hello :) first of all i would like to thanks all SF Members who always helped me out in the problems and guided me in the right direction and gave me good advises.
    Now here's my problem and i'm confused between my PSU and UPS that which one of them could be the problem. In my country the Power-Failure is very common and unpredictible and beside that our Electricity goes completely off from the Grid to save electricity (Government Lie) on scheduled timings which is about as good as 5 to 6 hours a day in my area for now (Sometimes it's much worse than that) so to save my PC from any harm and this problem i'm using a 1200VA UPS just to shutdown Windows and turn off my PC properly and safely within 5mins though the UPS is able to give 20 to 25mins of backup time. At the start of this month i bought a new Graphics Card. Today in morning i was playing Crysis and suddenly there was a Power-Failure (Blackout) and as soon as the Power-Cut happened my PC restarted during gameplay.
    Crysis is a game that uses the CPU & GPU at Max Peak and almost consume 90% or more power out of the PSU but the day i bought this Graphics Card i specially checked my PC by running Crysis on Max settings when my Power was about to go from the Grid and the PC did'nt restarted and in later days when i was playing Bulletstorm and few other games there was random Power-Failures and the PC did'nt restarted and the UPS managed to provide correct power to the whole system.
    I noticed one thing today that my UPS was charging the battery for a long time about 1 Hr and 40mins after this problem when the Power came back by the Grid and usually after 5mins of battery usage it only takes few mins to recharge. So now i'm confused and i'm not sure which one of the thing is creating this problem is it the UPS Internal Dual-Batteries or the PSU that is draining more power during Power-Failures? My UPS is 14 Months old and the PSU is approx. 9 months old and still as good as new. Today i even ran Crysis and Turned Off my LCD and Wi-Fi Rounter which are attached with the UPS as well to check if the UPS is overloaded but the PC restarted without LCD and Rounter too
    I used to had same problem with my old 400W Chinese PSU and 9600GT when i bought this UPS but some people suggested me on other forum (when i was'nt a member here) :) to replace PSU coz it had only 16amps on it where the 9600GT required 24amps. So when i replaced the PSU and got the one i'm still using i never had this problem since that day except today. I never had restart problem when i'm watching Movie, Browsing, Listen Music etc. This is all the info i can provide you now and hoping to hear from you guys and you may ask any questions if i'm missing something also my PC specs are below :) Please HELP!
  2. Posts : 2,164
    Windows 7 Ultimate 64bit
    Sometimes when the batteries are used more than not then they tend to not hold as much charge as when they were first purchased which will over time wear out and not hold any charge when trying to charge them.
  3. Posts : 24,479
    Windows 7 Ultimate X64 SP1
    First you should adjust you BIOS to remain OFF in a power failure.
    Since your power goes off daily, that has probably drained the batteries to the point where more charging was needed to get back to 100% charge. I'm guessing that is the case since it shut down right away in the power blackout.
    I doubt is the PSU is at fault assuming it is a good one and giving you 20%-25% more power than is needed.
  4. Posts : 4,198
    Windows 10 Pro
    Thanks for the quick response Zepher and Britton30 :) so the batteries need to be replaces?
  5. Posts : 24,479
    Can't say that for certain boogie, let them charge for several hours and pull the plug from the UPS and see if the PC shuts down right away or waits 5 minutes.
    You'd have to remove the batteries and check them with a battery tester.
  6. Posts : 249
    I understand your power situation completely, boogieboy! The US Virgin Islands has an outdated oil-burning power plant that goes off line from time to time. Everyone in their right mind here has a UPS for their PC!
    I do some network/internet work for a couple of resorts here & have found that UPS batteries do lose their stamina when they must kick in a few times a day. More than likely you need new batteries. If you still have problems after replacing the batteries, then there is an issue with the circuitry in the UPS & time to buy a new one!
    Please note that replacement batteries from the UPS manufacturer are often over-priced. I always order from a battery supply company that sells 12 volt, 7 amp hour sealed lead acid rechargable batteries. They are just as good & cost much less.
  7. Posts : 4,198
    Windows 10 Pro
    I just went into BIOS the 12v Voltage are Highlighted as red in the Power/Hardware Monitor menu where you can see the CPU Temps and Voltages what does it mean? is it something related to PSU that it's not providing sufficient voltages on the 12v rail due to the 6pin on the Graphics Card?
    @ Britton30
    My UPS is always fully charged :) and i also checked the UPS by pulling the plug out of the socket for 6 to 7 mins and the PC was running and suprisingly the UPS recharged very quickly like normal in 1 to 2 mins I talked to the guy from whome i bought it and he asked me to bring it and he will check the UPS and batteries
    @ TBoyd
    I agree with you and yes when i talked to that guy from the store and asked him about the price of Batteries so they were over-priced. i will look from other battery supplier. Sad to hear about this that it's happening at your side too. I hope the circuitry is working properly.
  8. Posts : 4,198
    Windows 10 Pro
    OK i checked the UPS and PSU by throwing the Breaker down from the DP Circuit of the house 3 times by running Crysis and probably the system was running at peak with LCD and router as well and the PC did'nt restarted even yesterday i was playing Bulletstorm and the Power Failure happened and it did'nt restarted I even checked by pulling out the plug for 2 to 3 times yesterday.... nothing happened. However i did took out the UPS plug before turning on PC and everyting and cleaned it and replug the cord. What could be the problem ?
  9. Posts : 249
    When you state that the PC didn't restarted when you threw the breaker down, do you mean that the UPS did not supply any backup power to your PC as soon as you threw the breaker?
    Any success yet finding new batteries?
  10. Posts : 4,198
    Windows 10 Pro
    no i meant when i threw the breaker from the circuit PC was running and Crysis (Game) was running and the UPS supplied the backup to the PC successfully and when turn back on the breaker the UPS recharged normally just like everytime. I tested 3 times.
    P.S. OK it happened again when i tested PC by running Crysis and as soon as the Power went down from the Grid (not the breaker) it restarted... So im assuming it's the PSU that is drawing more power from the battery on peak load and cant handle to provide clean power to the GPU. I think it's time to buy new PSU
