Samsung p510 Replacement Battery
Hi guys, i bought a 'replacement' battery off eBay, it does state below it is "Genuine Samsung Cells" but i doubt it, what use to happen before i formatted my laptop was when i plugged the laptop in to the mains it use to restart instantly and when i put it to sleep it restarts, i complained to the seller, and he suggested a reinstall, which so happened fixed the issue.
4 months later now though same thing has happened again, i dont really want to format, and i'm not sure if the battery is truly at fault (or more likely i cant prove it), it was fine and NEVER did such a thing with the ori battery
Details Below:
text ver of the html powercfg logCode:Something that concerned me not to be real Samsung cells Design Capacity 48840 Last Full Charge 65490 BATTERY FOR SAMSUNG P460 P560 LAPTOP NEW UK Replacement battery for Samsung P50 P60 R40 R45 R60 R65 R560 R700 X60 X65 Genuine Samsung Cells 1 Year Warranty VAT Registered UK Seller Battery Type: Li-ion Voltage: 11.1V Capacity: 4800 mAh Colour: Black Compatible Part Numbers: AA-PB2NC3B, AA-PB2NC6B, AA-PB2NC6B/E, AA-PB4NC6B, AA-PB4NC6B/E, AA-PB6NC6B, AA-PB9NC6W, AA-PB9NC6W/E, AA-PL2NC9B, NBP001513-00, NBP001535-00
