Samsung p510 Replacement Battery
Page 1 of 3 123 LastLast
  1. Posts : 375
    Windows 7 Ultimate N 64-bit
    Hi guys, i bought a 'replacement' battery off eBay, it does state below it is "Genuine Samsung Cells" but i doubt it, what use to happen before i formatted my laptop was when i plugged the laptop in to the mains it use to restart instantly and when i put it to sleep it restarts, i complained to the seller, and he suggested a reinstall, which so happened fixed the issue.
    4 months later now though same thing has happened again, i dont really want to format, and i'm not sure if the battery is truly at fault (or more likely i cant prove it), it was fine and NEVER did such a thing with the ori battery
    Details Below:
    Something that concerned me not to be real Samsung cells
    Design Capacity 48840
    Last Full Charge 65490
    BATTERY FOR SAMSUNG P460 P560 LAPTOP NEW UK
    Replacement battery for Samsung P50 P60 R40 R45 R60 R65 R560 R700 X60 X65
     1 Year Warranty
     VAT Registered UK Seller
    Battery Type: Li-ion
    Voltage: 11.1V
    Capacity: 4800 mAh
    Colour: Black
    Compatible Part Numbers:
    AA-PB2NC3B, AA-PB2NC6B, AA-PB2NC6B/E, AA-PB4NC6B, AA-PB4NC6B/E, AA-PB6NC6B, AA-PB9NC6W, AA-PB9NC6W/E, AA-PL2NC9B, NBP001513-00, NBP001535-00
    text ver of the html powercfg log
    Samsung p510 Replacement Battery Attached Files
  2. Posts : 375
    anybody plz?
  3. Posts : 375
    ok i deleted hiberfil.sys and it worked when i out it to sleep for first time, but then i turned back on, and it went back to post BIOS screen
  4. Posts : 375
    just did a clean install with same issue though.
    in the laptop i have a kingston SSD, that wouldnt be causing issues do you think when its put to sleep
  5. Posts : 24,479
    Windows 7 Ultimate X64 SP1
    I have no idea Rich, help requested for you.
  6. Posts : 375
    no problem, thank you for reply, was talking to myself for a while then
  7. Posts : 24,479
    Yes you were, sorry about that.
    In your code, it doesn't say that battery is for a P510? I don't think a battery would cause your issues. Have you tried with the battery removed and plugging in to your mains only?
  8. Posts : 375
    Touché
    I did try this several months ago and the out come was the battery at fault.
    I have just tried several boots then, sleep and hibernate and yes every time it went to sleep it simply restarted.
    But also the issue i get aswel is the laptop having only what i can describe as a electrical short.
    When plugging the charger into it, the laptop again will just instantly restart i.e. back to post BIOS beep.
    Just done a clean install of ultimate n SP1 with only changes to services and no other system changes, just installed also Samsung chipset drivers, i am still about 40 latest updates behind from M$
    And yes it doesn’t say for p510 but the part numbers match from the ori battery
  9. Posts : 24,479
    Hmm, maybe the battery connections are faulty, loose, or bent. Could be dirty too, in the laptop, try the pencil eraser trick and rub it on the connectors to clean away any unseen corrosion.
    Do I understand correctly:
    The computer restarts when you try to go to Sleep mode?
    If you plug in the mains, with the computer powered down, it restarts.
    You should have Sleep disabled when Plugged in, and enabled to, say, 15 minutes on battery. From your text attachment you have the opposite.
  10. Posts : 375
    its not the battery connections, it did look like to be battery several months ago, but currently it does it on mains only, so its not connectors
    yes when i sleep, - it turns on and goes to BIOS screen straight away instead of waking up
    when i hibernate, - it turns on and goes to BIOS screen straight away instead of waking up
    IF it goes to sleep ok, - it turns on and goes to BIOS screen straight away instead of waking up
    and yes i did have that, but after a clean install of ultimate x64 N it still does the same, so all windows settings have gone.
    latest energy report after format.
