Samsung p510 Replacement Battery
  1. Posts : 24,479
    Windows 7 Ultimate X64 SP1
     Platform Power Management Capabilities:Supported Sleep States
    Sleep states allow the computer to enter low-power modes after a period of inactivity. The S3 sleep state is the default sleep state for Windows platforms. The S3 sleep state consumes only enough power to preserve memory contents and allow the computer to resume working quickly. Very few platforms support the S1 or S2 Sleep states.
    S1 Sleep Supported false
    S2 Sleep Supported false
    S3 Sleep Supported true
    S4 Sleep Supported true
    This is kind of interesting, saying some of the sleep states are supported. Is there power or suspend state setting accessible in your BIOS? If so set it to S3.
  2. Posts : 375
    Windows 7 Ultimate N 64-bit
       #12
    mmm yes fairly strange. just checked BIOS no power settings within there, which is strange but conceivable
    it does say at the end of that sentence "Very few platforms support the S1 or S2 Sleep states"
    so its what is supported by OS, so windows 7 must only support S3, S4
  3. Posts : 24,479
    You might try the Default power settings for Balanced and Power saving. Gotta admit this is odd and I don't know what else to try.
    Yes, S3 should be the default for most BIOSes.
  4. Posts : 375
       #14
    UPDATE!
    apparently on most samsung's there is a hidden BIOS tab 'intel'
    FN+F11 let go of both buttons then FN+F12
    just changed some basic (advance) BIOS settings (i.e. only what i know is what) still no sleep settings within their though, but it has just worked fine going to sleep for the last 4 months on my ori install of ultimate 64 N
  5. Posts : 375
       #15
    there are more submenus, but i dont think u want 20 photos do u, lol.
    Attached Thumbnails Attached Thumbnails Samsung p510 Replacement Battery-dsc01053.jpg   Samsung p510 Replacement Battery-dsc01054.jpg   Samsung p510 Replacement Battery-dsc01055.jpg   Samsung p510 Replacement Battery-dsc01056.jpg   Samsung p510 Replacement Battery-dsc01057.jpg
  6. Posts : 375
       #16
    images 2
    Attached Thumbnails Attached Thumbnails Samsung p510 Replacement Battery-dsc01058.jpg   Samsung p510 Replacement Battery-dsc01059.jpg
  7. Posts : 375
       #17
    sorry, also i appreciate your time and knowledge
  8. Posts : 24,479
       #18
    Thanks Rich that BIOS has some terms I've not seen before.
    On my HP desktop I press F1 to enter BIOS, but if I press F11, there are more settings to foul up change
  9. Posts : 375
       #19
    ok thanks for the info, think im going to flash BIOS again, and do another clean install on a diff HDD
    (currently just installing XP, then if still persists vista then a diff ver of 7 i have)
    i also spoke to samsung who pointed me to M$
  10. Posts : 375
       #20
    found my issue!!!
    well i beleive anyway
    when doing a bios upgrade, win 7 was saying it was ok and it had complete, but when i looked it actually hadnt, and i couldnt get it to perform.
    windows xp installed re-ran the bios upgrade util BIOS updated and now seems ok
    (i had missed this and failed to notice the BIOS not updating)
