Need help finding a good monitor for xbox 360/7 compatible
  1. Posts : 56
    window 7 64b SP1
    I want one thats not over $400.20"-35" is fine.
    Looking for:
    10000000:1 contrast ratio
    2ms response time
    120hz
    1080(1920 x 1080)
    That is just all I know to look for in a monitor.Basicly whatever gives best gaming experiance and also able to work on 7 also.I would really like a 3D,but fell thats probably not in my budget.And if so,it would probably be under 20"
  2. Posts : 402
    Actually, do you need speakers built into the monitor? I only ask since I know of two ASUS monitors that I believe fit all your requirements, and are also beautiful to look at.
  3. Posts : 402
    But they're like, 23, 24 inch widescreens though....
  4. Posts : 56
    window 7 64b SP1
    I just now added 120hertz.Forgot to add that.60hz will work,but the higher the beter is what I hear.Yes I noticed asus has quite a stockpile of monitors.I don't care for the speakers.Most probably don't sound all that good.I got a sourround sound to take of sound.I don't mind widescreen,seems like 1080 is made for widescreen anyway.
  5. Posts : 402
    Hmm, 120 hertz is going into the television spectrum. Honestly, if your eyeballs can see 60 images a second and notice it, then 120 hertz would be better. That is good for TVs since if you're like watching sports or anything and the camera follows a really long kick of a ball, it'll have less of a blurriness to the ball. But for gaming, I doubt 120 hertz would do you much since 360 games if I remember correctly have a frame rate of about 30 frames per second.
  6. Posts : 56
    window 7 64b SP1
    I thought the hertz can be adjusted anyway though.Like if its to much for what im using I go in the menu and make it less if needed.
  7. Posts : 402
    Well, if you need to make it less, than the average puter LCD monitor will fare fine.
    The hertz rate is how many times a screen refreshes the image per second to avoid flicker. Tube monitors had that issue. If you ever videotaped a CTR monitor, you'll see the refresh rate pretty easy. LCDs, not so much. Having If you plan on using it for 7, a refresh of 60Hz is the base. And if you connect it using DVI from the puter, it'll be 60Hz. I believe many HDMI outputs from graphics cards might also run at 60Hz.
    I just looked into this real fast, the 360 does have a 30 FPS refresh for games, and a hertz refresh of 60.
