Problem with Intel Management Engine Interface
  1. Posts : 3
    Windows 7 Home premium 64 bit
    Everytime I start up the computer and check device manager, there are yellow exclamation marks on my network adaptor and Intel Management Engine Interface error. It says that the device cannot start (code 10). However this all goes away when I restart the computer; but happens again when I "shut down" and turn the pc on again. I have tried formatting windows 7 several times but problem still persists. How can I fix this so that these devices start on my first startup?
    i5 2500k
    asus p8z68-v pro
    windows 7 64 bit
  2. Posts : 1,996
    Windows 7 Home Premium 64 bit
    You may want to try re-installing the chipset driver.
  3. Posts : 3
    from the motherboard cd? do i have to uninstall the driver and then reinstall? or just reinstall over it?
  4. Posts : 1,996
    Yes, you can just re-install it over the old installation.
    Try the driver from here......ASUSTeK Computer Inc. - Motherboards- ASUS P8Z68-V PRO
  5. Posts : 3
    unfortunetely problem is still there.. Is this a faulty motherboard or driver related problem?
