Monitor makes a high pitched noise when showing white.
  1. Posts : 664
    Firstly, apologies for the vague thread title, I couldn't think of how else to describe it
    Right, when the monitor (rather old 16" Sharp LCD monitor) is showing the colour white (such as a Google search results page, GMail inbox etc.) I can hear a rather audible high pitched buzzing sound, no matter what brightness the screen is on. Any ideas as to why? I'm sure there is a scientific/electronic reason as to why, it's just I'm not sure what that reason is
  2. Posts : 6,292
    I have read that the condition can be caused by low quality capacitors.
    And I understand the fix (workaround) is to lower the refresh rate as low as it will go.
    Also could be the power inverter for the backlight (same reason: cheapness).
    Some people say you can epoxy the edges of the inverter to fix this. Not advisable IMHO - just replace it.
    And if the backlight is fluorescent, then you could be hearing that common buzz that fluorescent lights make when they are close to burning out.
  3. Posts : 664
    well, thank you very much for the in-depth information!
    I managed to change the refresh rate down and the buzzing lessened greatly, so thanks for the tip .
    It is an old screen, so I wouldn't be surprised if it was dying Hopefully I'll be buying a new monitor soon that actually compliments my new PC, but thanks for clearing up the high pitched buzzing noise and explaining reasons for it
    also, Grim Fandango FTW!
  4. Posts : 6,292
    Manny is the hombre .
  5. Posts : 664
    yup, he definitely is It was an AWESOME game, especially considering it's from 1998. Sure, it was a fixed (but varying) viewpoint but it was so much fun
