dvd drive problem
  1. Posts : 9
    win 7
    dvd drive problem
    I have laptop Acer 5738z with Vista x64 and I have installed Windows 7 RTM x64 as a second system on it with no trouble, everything works well except DVD drive I can't instal any software from dvd because either dvd stops working during instalation or even not stars at all. On Vista this problem not occurs.
    Anyone had this problem too?
  2. Posts : 748
    Windows 7 Professional x64 PL
    Control Panel>>Troubleshooting>>Hardware & Sound:choose Configure device ->this will run build-in hardware autodiagnostic.If still no help open device manager,navigate to CD/DVD section and check you have any error relate to DVD -present it here.Probably you may have problem with UpperFilter,LowerFilter in HKLM\System\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318} -if you have these phrases in this key you have to remove them.Details:Your CD drive or DVD drive is missing or is not recognized by Windows or other programs but this procedure you have to do it manually because MS Fix it still don't work under Windows 7
  3. Posts : 9
    win 7
    Thanks for reply but unfortunately it didn't help me the problem stil occurs. Apart from this trouble I have also problem with connection to the internet. I use a cable connection which on vista works fine but on Win 7 doesn't.
    ps. a poza tym to pozdro :)
  4. Posts : 748
    relate to DVD:
    Try below:
    1.Make sure the service Shell Hardware Detection is started and set to AUTO
    2.Navigate to key HKLM\System\CurrentControlSet\Services\Cdrom and check you have phrase Autorun =1,if is 0 fix it + restart
    3.Update driver for DVD (look in Windows Update,munufacturer website)
    4.If everything fail download FrogAspi http://www.frogaspi.org/download.htm#frogaspi
    (when you download make sure the module is already renamed to wnaspi32.dll -otherwise you have to rename)
    if you have x64 system place wnaspi32.dll in C:\Windows\SYSWOW64 again uninstall DVD driver + restart
    if you have x32 system place wnaspi32.dll in C:\Windows\System32 again uninstall DVD driver + restart
    5.If stiill nothing help unistall program for CD virtualization like Alcohol 120,Deamon and likely and all programs for burning DVD
    6.You can also try uninstall IDE controlers in device manager -system reinstall it after restart.
    7.Updating drivers for chipset and update BIOS also maybe helpful
    Besides in device manager in DVD section: Isn't any error warning relate DVD,no yelow triangle or down arrow on DVD?
    Make sure you don't have any double or more firewalls,antiviruses -if yes you have to uninstall them
    Next Run cmd.exe with administrative previlliges (right click on cmd.exe as admin) and type
    netsh winsock reset
    + restart
    Ja tez pozdrawiam rodaka :)
  5. Posts : 623
    vista x64/ win 7 x64
    about the same: my dvd sometimes shows up, sometimes doesn't. If it doesn't show i reboot with a bootable dvd in it. That seems to help.
  6. Posts : 748
    None of advices from my previous posts (2 and 4) no help?I think when your DVD missing you have error 22 in device manager:down arrow on DVD "device is disabled" -check it I have right or not.Apart of them I present interesting thread where responsible for missing DVD was USB HDD.If you have any USB HDD unplug it. See:DVD Drives go missing Vista64 sp2 - Vista Forums
  7. Posts : 623
    for me at least, since it works most of the times but not all of the times, and when it works it works fine all your very good suggestions are to no avail.
    It's the same with my audio, if i want to play via the speakers, i first have to play a few seconds via digital else only the left speaker works.
    The drivers and 7 are not quite done yet.
  8. Posts : 9
    win 7
    Unfortunately not, now I'm working on Vista and trying to update bios but I also have trouble with this, on 7 I still can't get access to the internet to download updates. It is all strange, maybe my notebook is unlucky :/
  9. Posts : 748
    Maybe any non-typical unnecessary driver not relate to burn programs or drive virtualization cause this:
    Make log from drivers -two methods (to choose)
    METHOD I
    Run cmd.exe with administrative previlliges (right click on this file as admin) and type:
    wmic sysdriver get name,Description,DisplayName,Name,pathname,startmode >%userprofile%\Desktop\Driver.txt
    METHOD II
    Run PowerShell (command line) and type
    get-WmiObject -class Win32_systemdriver |format-table DisplayName,Name,pathname,startmode >$env:userprofile\Desktop\Driver.txt
    On your desktop appear Driver.txt file->attache it to post
    @tutis
    relate to network issue
    in Control>>Panel>>Troubleshooting>>Connect to the internet <-Have you tried this option?
  10. Posts : 9
    win 7
    here is a log file Driver.txt
