Need Help some advice , Please !
  1. Posts : 5
    Window Home Premium 64 bit
    Hi Um.. I have problem with extra memory ram 2GB added on my 785GM-E51 motherboard which mean that they said dual channel ? mean that I must have to buy dual channel memory ram or normal ? because when I put two of 2x 2GB total 4GB with Memory ram that got me crash BSOD blue death ... I dont understand why with it ? I dont want mess up with BIOS setting and not sure how to fix it for my 785GM-E51 motherboard ... it took me few hour and crash wont work out with 4gb into memory slot that they have 4 slot of memory slot which it is two black and two blue on it .. I dont know why and not sure what wrong with it .. please help ! thanks !
  2. Posts : 12,012
    Here is your motherboard information from the manufacturer:
    MSI Global - Computer, Laptop, Notebook, Desktop, Mainboard, Graphics and more
    Here is the required memory specification:
    Supports four unbuffered DIMM of 1.5 Volt DDR3 800/1066/1333/1600*(OC) DRAM, 16GB Max
    I would make sure that the memory meets the above specification and I would try it in both blue slots or in both black slots.
    Here is the list of qualified memory modules:
    http://www.msi.com/file/test_report/TR10_1866.pdf
    If possible, I would use memory that appeared on the above list, but other memory may work if it meets the specifications of unbuffered 1.5 Volts DDR3 800 or 1066 or 1333.
  3. Posts : 5
    do I have to follow them for my bios setting on my 785GM - E51 ... i did check MSI .. look fine to me .. but I need to know if I setting with it.. then I can add other stick to put in my memory slot #2
  4. Posts : 14
    Windows 7 Ultimate 64bit, Windows 7 Home Premium 32bit
    ignatzatsonic answered your question, but remember to buy RAM which also matches your other RAM stick's clock (in MHz) or system instability might be caused.
