external drive HELP need please
Page 2 of 6 FirstFirst 1234 ... LastLast
  1. Posts : 36
    win 7 64bit
    essenbe said:
    If that does not work, try Recuva. But first I would try diskpart. Open an elevated command prompt ( click start, type cmd in the dearch box, right click on cmd and select run as administrator) In the box that comes up, type diskpart, press enter and in a few seconds the window will respond by saying diskpart. Type list disk and it will list all disks connected to your computer. type select disk # (where # is the number of the disk you are having issues with). press enter. it will respond with disk # is the selected disk. Type assign and press enter. If this works, it will assign it a drive letter. Type exit and press enter twice to close the window.In that case you can open it with explorer and look at the files inside.
    when i get to `Type assign and press enter` on your tut i get `There is no volume specified. Please select a volume and try again.
    am i doing something wrong?
  2. Posts : 26,870
    Windows 11 Pro
       #12
    No, probably not. Check the connections to the drive and try the tut again. this time when after you do the list disk and it says disk # is the selected disk, type list partition and press enter. If it lists partitions, type select partition 1 and press enter, then try assign. if that works you need to do it for each partition it lists. This may not work, but it is worth a try.
  3. Posts : 7,730
    Windows 7 Ultimate SP1 64-Bit
    Will trying in Safe Mode be of any benefit?
  4. Posts : 26,870
    Windows 11 Pro
       #14
    The honest answer is, I don't know. But it won't hurt either. The truth is that it shouldn't be doing this to begin with, in my opinion. We have had several threads with people putting XP drives in windows 7 machines and 7 not recognizing them, and it should.
  5. Posts : 11,269
    Windows 7 Home Premium 64 Bit
       #15
    This may be a permissions issue. I've had this problem myself, and right clicking the drive in My Computer, clicking properties, going to the Security tab, clicking Edit, and adding Users to Group or user names: fixed it for me.
    Edit: Group or user names: Administrators, SYSTEM, and Users should be listed for the drive to work.
    Edit 2: Fixed procedure to include clicking properties after right clicking the drive.
  6. Posts : 26,870
    Windows 11 Pro
       #16
    writhziden said:
    This may be a permissions issue. I've had this problem myself, and right clicking the drive in My Computer, going to the Security tab, clicking Edit, and adding Users to Group or user names: fixed it for me.
    That may be the next hurdle, but I don't think it will show up in my computer without a drive letter.
  7. Posts : 11,269
       #17
    You're right, I should have added that. The user should be able to go into Disk Management and assign it a drive letter after making it active.
  8. Posts : 11,269
       #18
    If what I said above doesn't work, look at Free Format Recovery Software | Recover files after format free | iCare Format Recovery Free I have the paid version of this software and was able to recover files from a RAW drive before.
  9. Posts : 36
    win 7 64bit
       #19
    assign doesn`t do anything this is what i get
  10. Posts : 36
    win 7 64bit
       #20
    when i right click the drive i cannot see a security tab in the drop down?
