need help resurrecting usb flash drive
Page 2 of 2 FirstFirst 12
  1. Posts : 55
    Windows 7 Pro 64bit
    According to their website that product carries a lifetime warranty. Send it back and get another.
    OCZ Rally2 USB 2.0 Flash Drive - OCZ
  2. Posts : 1,777
    MS Windows 7 Home Premium SP1 64-bit (Family Pack Lic.) Upgrade
       #12
    quick grab it from the landfill
  3. Posts : 8,398
    ultimate 64 sp1
    thanks a lot for that 1foxracing.
    it actually says "limited lifetime warranty" - not sure what that means, i'll investigate further.
    +rep for you
  4. Posts : 10,455
       #14
    What if anything does it show in Disk Management?
  5. Posts : 8,398
    ultimate 64 sp1
       #15
    hang on, i'm just scraping off all the cat food and coffee grinds from it first....
    disk management just hangs at 'connecting to virtual disk service' if i start it with the drive plugged in.
    if i start diskmgmt without it plugged, then plug, then refresh or rescan, the little blue circle spins and spins to no avail.
  6. Posts : 10,455
       #16
    Shame. Sounds like it can go back with the cat food and coffee grinds.
