Need Help Connect PC to HDTV
I have a Lenovo H405-7223-1GU that I bought in June 2011. Yesterday I bought a Philips 32" HDTV 720p 60Hz. My PC won't recognize my TV at a monitor via HDMI cable. The ports on the TV and the cable is fine because I can connect my DVD player with no issues. Most help is saying to right click desktop, click "screen resolution"and then just tell the PC it's ok to send info over HDMI. That would be fine but I can't have my monitor and HDMI plugged in at the same time. As soon as the HDMI is plugged in my monitor (VGA) goes blank then comes back on with only the background image showing. No start button, no icons, no toolbar. I can see my mouse cursor when I move it but that is it. As soon as I remove the HDMI cable, my monitor comes back. Any ideas? Thanks
