Speed up fan
Page 1 of 3 123 LastLast
  1. Posts : 34
    Speed up fan
    Is there a way to make the fan go faster
    its a stock heatsink from an amd athlon 64 x2 5200
    it looks like its spinning kind of slow
    what is the best way to check the temp and at around what temp is a good temp to keep it?
  2. Posts : 1,161
    Windows 8.1 PRO
    Use SpeedFan..
    http://www.almico.com/speedfan439.exe
    What's the RPM of your fan..
    There can also be BIOS options but we will get to that after.
  3. Posts : 34
    here is what speedfan says
    fan1: 1722 rpm
    fan2: 788 rpm
    temp1:37c
    temp2:28c
    temp3:72c----this one has a picture of fire next to it..i think thats bad
    core:11c
  4. Posts : 4,573
    Try finding a config for your mobo at SpeedFan's site. The path to get there begins in SpeedFan's settings - get a ticket and submit it. I don't have SpeedFan fired up so I can't get specific.
    The configs will give a definition for what component each temp/speed is referring to. They are unique to each mobo model. You are at the mercy of the person who uploaded the config, however. There are some which are, maybe not stupid, just not, well there are some stupid ones. I had to test a number of them out before I found a valid one.
    The 72 is warm, but not out of range - for the Northbridge. I am assuming it is the NB temp.
    Unless the fans are fairly large, those speeds are not moving much air.
  5. Posts : 6,879
    Win 7 Ultimate x64
    Cool'n'Quiet, enabled or disabled? Check in the bios and if enabled, disable it.
    Also while there have a look under Power Management and see if "Smart Fan Control" is enabled, and if it is disable it.
    In all likelihood that is a phantom reading, meaning the monitoring chip is capable of supporting/reporting that reading but there is no sensor attached on the motherboard for that reading.
    That would here,
    SpeedFan Configuration Manager
    you need to register first, and then just follow along till you find your motherboard (if it is there. You can also look here,
    SpeedFan's listing of motherboards that are known to change fan speeds
    and see if it has been reported to work, but will still need to go through the first link to get the config.
  6. Posts : 34
    i looked in the bios and i didnt see coolnquiet but i did see smart fan control
    there is system smart fan control and cpu smart fan control
    do i disable both of them?
    i dont think they have my motherboard
    its this one
    Newegg.com - GIGABYTE GA-MA74GM-S2 AM3/AM2+/AM2 AMD 740G Micro ATX AMD Motherboard - AMD Motherboards
    but i checked and its not there
  7. Posts : 6,879
    Win 7 Ultimate x64
    That helps, just checked the manual for your board. You will find the setting for C'n'Q under "Advanced BIOS Features", and it is set to Auto by default which will cause the fan to run a a slower (and quieter) speed when there is no load on the CPU.
    The "Smart Fan Control" sort of does the same thing, only it runs the fan at a speed based on the temperature of the CPU. It too is set to Auto by default, and if disabled the fan will run at full speed. BTW disabling the "Control" will also disable the "Mode" options.
  8. Posts : 4,364
    Windows 11 21H2 Current build
    Even so, though, that is abnormally hot - I'd say you need to check to make sure the heatsink is making proper contact with the CPU and that you applied enough (meaning not too much and not too little) thermal compound in the process.
  9. Posts : 34
    this was my first build ever so i am not sure if i did something wrong
    the cpu (amd athlon 64 x2 5200) already had thermal compound so i did not apply any more
    was i supposed to put some more?
    ok so i disabled cool n quiet, cpu smart fan control, and system smart fan control
    is that correct?
  10. Posts : 4,573
    Double check with real temp or your mobo bios, but I am highly confident that the 72c is your northbridge - accurate reading or not.
