Options for setting up a wireless printer
  1. Posts : 128
    MS Windows 7 Ultimate 64-bit SP1
    I recently picked up a old HP psc 2510 photosmart all-in-one printer at a yard sale for 10 bucks in great condition. Problem is, it was missing all documentation and driver CD. Fortunately, HP included "in-OS" drivers for Win 7, so I was able to set it up over USB very easily. But now I'm trying to get it up and running with wireless printing, which it supports on XP, but isn't perfectly ported to 7.
    Following the advice from the 4th comment on Re: HP PSC 2510 Photostmart drivers for WIndows 7 - Page 4 - HP Support Forum, I was able to connect to it via my wifi network when I plug an Ethernet cable into the printer.
    Now, this works, but being a huge nerd, I think it'd be even better if I could set the printer up to be completely wireless. I'm not much of an expert on the finer workings of wireless connections, but I think it's possible to do this with an ad hoc netwrok. But I can't find any instructions for doing this on 7. Closest thing I found was this page with instructionsfor XP, which I was unable to follow on 7.
    Since the printer has an on-screen option to enable or disable the "wireless radio" which can only be turned on when the ethernet cable is unplugged, I assume this functionality is to broadcast the "hpsetup" ad hoc network from the printer without it being connected to a router (since I don't think it can connect to an actual wifi network wirelessly; but if it can, it'd be great to know how to do that too!). But even when I do see the hpsetup network in my wifi list, I can never connect to it from my laptop.
    I have a feeling I'm probably missing some important concept of how ad hoc networks work, and that that pack of knowledge is the cause of all my problems If anyone could help me out here I'd really appreciate it. If worse comes to worse, I'll just be happy printing over wifi with the printer connected via ethernet to my router. But I'm sure theres a way to set it up totally wirelessly. thanks!
    P.S. I'm the same Slammer from over at vista64 forums, and I'll update all my profile stuff sometime tomorrow :) so hi to anyone I know from over there!
  2. Posts : 388
    Windows 7 Home Premium 64 Bit OS
    Instructions for creating an ad hoc network in Windows 7 can be found here:
    Windows 7: How to Create an Ad Hoc Network | kombitz.com
    I also wonder if maybe it has anything to do with encryption?
    It seems that with the linkout you have provided with instructions
    for setting this up in XP describes setting up WEP encryption connection
    through the HP setup page. Wondering if the device you are making the
    ethernet connection to is handing the printer an IP by checking that option in
    the setup through Win7 (Automatically obtain IP address therefore it should) but check if the router is also using
    WEP encyption which whilst reading the documentation seemed to be required for the printer.
    Is that making sense! I'd start with that first :)
  3. Posts : 225
    Windows 7 Pro x64
    You should leave the network cable plugged in, then open IE or what ever web browser you use and enter the ip address of the printer, you will now be able to navigate through the printer and set up the wirless connection. Once you have setup the wirless connection you can then disconnect the the network cable and you should then be able to print wireless.
  4. Posts : 2,164
    Windows 7 Ultimate 64bit
    Why not set it up on your wireless network? This will be the easiest way. Unless this is what you actually mean and just mentioned ad-hoc by mistake.
    I guess read everything on the page,
    http://h20000.www2.hp.com/bizsupport...ctID=c01941827
  5. Posts : 128
    Thanks for all your replies.
    @AllOnTheBus- See I think this is part of what's confusing me. Is that setup page for joining a network, setting up an actual WLAN (wireless) network independent of my actual router wifi, setting up an independent ad hoc network, or all three? Because under "Select Network Name (SSID):" I have both "linksys" (the name of my normal wifi network) and "hpsetup" (I assume the name of the printers optional ad hoc network) options available. But I don't know which one to choose (or if I should make my own name instead). As for your WEP theory, I don't think it's required. My router is handing the printer an IP address (192.168.1.116) when I connect it via ethernet, and I can access that setup page easily though my browser. I just don't understand exactly what that page is for: setting up a connection, or connecting to my existing internet network.
    Now, here's my understanding of how ad hoc works: it's similar to bluetooth in that it allows you to communicate with other devices in a limited range, without having to connect to an internet/wifi network, as long as all the devices support ad hoc. But instead of bluetooth, it's run similar to an actual wifi network, with one device broadcasting the SSID (and therefore "hosting" the ad hoc network) and then the rest of the devices connect to it. So it's effectively like hooking all the devices up with Ethernet cables, but doing so wirelessly. Is this right? Because I'm assuming that my printer should be able to "host" that ad hoc network, and that my laptop should be able to connect to it to printer. Anyway, that's what I'm trying to do based on my limited understanding of how these networks work. Please correct me if I'm wrong.
    @mgp1964-
    mgp1964 said:
    ...navigate through the printer and set up the wirless connection.
    Setting up the wireless connection is where I'm having trouble. :)
    @Zepher- I was able to set it up by connecting it to my router via Ethernet, finding the IP address my router gave it, and then setting up a printer on my computer that looked at that IP address to find the printer. It works that way, but a) I don't know if that IP address is always going to be reserved for this printer, or if it might change and force me to re-set it up if/when it does change. And b) my ultimate goal is to set this printer up in a room in my house away from my router and on it's own separate (possibly encrypted) ad hoc network. That way other people who want to print from have to have access to that ad hoc network, and not just my wifi network (which for various reason is unencrypted, so literally anyone within range could print anything to it if it's hooked up directly to my wifi).
    But to do have it in a different room means I won't be able to connect it to my router with an Ethernet cable, so I need to either figure out how to connect it wirelessly to my internet, or set up it's own ad hoc network that doesn't need any connection at all to my wifi/internet network. It's just that I prefer the ad hoc solution, even though I know it'll be harder. I'm willing to stick with this until I get it done :) Also, that link you gave seems to be dead. Not sure what the deal with that is.
    Thanks for taking the time to read all this. I know it's a lot, but I'm bent and determined to get this working. :)
  6. Posts : 2,164
    first thing you should do is secure your wireless network.
    If the link you are referring to is the link I posted, I just checked it and it is working for me.
    here is the page to setup an ad-hoc network on the Printer.
    Setting up the Printer (Wireless Ad hoc) HP PSC 2510xi Photosmart All-in-One Printer - HP Customer Care (United States - English)
  7. Posts : 128
    Hmm yeah the link seems to be working now. Weird.
    I know the network should be secured, but sadly, I'm not in charge of it. Another family member is, and for some reason he just doesn't see the need to encrypt it and I haven't been able to convince him otherwise. I'm sure some day someone will finally use that to attack our network and then he'll add it, but until then I just have to deal with it. And I've been trying to follow those instructions on that page, but they're all for XP and can't find all the equivalent options in 7. But the biggest problem is that I don't know if that printer setup page (In step 4) is for setting up a network just for the printer, connecting to my wifi network, or both. And until I know which parts are for which, I don't know what information I'm supposed to be entering. It's all to ambiguous. For example, there is both an "Authentication" and "Encryption" header, and they both seem to be very similar in what they're asking. And I don't know if they're asking for the info for my wifi network, or for the network I'm trying to set up. Ugh, maybe I'll just contact HP support and ask them....
  8. Posts : 128
    Ok I think I've figured it out. Near as I can tell, if you chose "Select Network Name (SSID):" and pick your existing network name, then it will connect wirelessly to that network after you unplug the Ethernet cable and then enable the Wireless Radio in settings. I'm just not sure what selecting "hpsetup" does because that should be the network the printer makes, not one I can "connect" to. Maybe I'll check into it some other time.
    But if you choose "Enter Network Name (SSID):" and select Ad hoc for Communication Method, it creates an ad hoc network from the printer. But from what I can tell, it won't create it's own Infrastructure network, even if you choose that option and enter a name. Which I suppose probably makes sense.
    I actually found it much easier (with better explanations for the various options, too) to just choose the "Advanced Configuration" button and set it up that way, because it provided a kind of easy "setup wizard" to follow.
    Also, I discovered that I can't be connected to the ad hoc network and my wifi at the same time, so that kind of ruined my plans for that. But I was able to connect it to my wifi without the Ethernet cable, so that's the next best thing. Now it really prints wirelessly, and I can set it up in another room just like I wanted. I wonder if I can set up a password for using it since it's on my open netowrk.... Anyway, thanks for everyone's input!
  9. Posts : 388
    I'm sure you probably came across this information during your search
    for answers, but an ad hoc network is only a fast setup temporary network
    connection unless you choose otherwise (ie: save the network/connection).
    Obviously your printer is being allocated an IP address within the network range
    therefore allowing it to communicate with other network devices, or at least allow
    packets of information to be sent to it. From what I have read though, once the
    ad hoc network is set up, the network connections do not need to rely upon
    the router or access point to keep communicating or again, to at least be communicated TO.
    I was wondering if you might be able to see if your family members machine is able to see
    the printer once the ad hoc connection has been made or are you as the original "maker" of
    the ad hoc network configuration responsible for then allowing access / share permissions
    to the printer through homegroup and sharing options considering that the ad hoc network works
    independantly of other networks (ie: the wireless access point connecting your machine to the wireless router).
    Hmm - interesting. I gotta be honest and say that I haven't had to much to do with wireless
    networking which more than likely is coming across here as plain as day but please let me know if you can gain access to your family members machine and provide some answers to the previously mentioned questions. I look forward to your response.
    Anyways - glad to here that you have come to a conclusion which in part
    has satisfied your requirements.
  10. Posts : 5,795
    Maybe I'm missing something, but since you say you are a huge nerd, this should be a piece of cake. You should know your network name and passkey. If you don't have a passkey, set one now.
    Then, follow the on printer instructions to enter the name and passkey. That's it. I've set up a dozen wireless printers for my home office employees, and the HP ones are the easiest to do.
    You shouldn't be using an ad-hoc network at all, considering you have a router.
