Right Click ACPI Fixed...
UNINSTALL
On the Menu Bar,
Scan for hardware changes
Let Windows re-install the device.
UNINSTALL
On the Menu Bar,
Tried that... Still nothing has changed.
Do not misunderstand this link:
CDROM-Guide forums - View Single Post - Microsoft USB 2.0 drivers XP
It is provided ONLY as background for the following:
You have an antique mobo, relatively speaking. It is possible that later releases of Win7 contain a corrective driver set.
Try Build 7201 or later.
I could be wrong. This problem exceeds my ability to assist.
I am unable to upgrade to the newer build it wants a clean install. All my stuff is on here at this point.... to save it to a HDD again would take forever at 1.1 speeds
I want to give up
lol.... I can't do it tho... My computer usually get rebooted when the power flicks here.... it wouldn't stay on for 3 days.
The yellow line indicates there are no drivers available for this device - go to your motherboards site, or intel, or AMD, and download the latest vista chipset drivers for your your motherboard - if they wont install because of an OS mismatch do the following -
To install a driver OR program in compatibility mode - right click the setup.exe file - click properties - click compatibility - check run in compatibility with vista - check run as administrator - leave the rest blank. Start setup.exe and install.
Hi Guys
Have read through this post, I have similar problem though I'm more confused now.
I have 3 External HD and one Semi-External (backup unit HP). None of them works through USB ports (none of my 8 ports).
Not even the four Mem sticks I have tried works.
W7 says unknown devices.
1. I have tried all ports.
2. I have tried on Vista and XP on other machines (no problems).
3. I have had these units working on this hardware before (in vista).
4. I have the latest of everything as it seems.. (i think).
5. I have reinstalled with them plugged in and not like 4 times..
6. I have tried several updates and even tried with old USB drivers..
7. I found a writing on a 4 step check and did that to (power management, uninstall, checking power etc.. )
What the H...
My keyboard works (W-less).. My Camera works.. ? on all ports..
Any one have similar problems ?
This is driving me crazy ..
Best Regards
Harry
