Noisy multi speed Fan
Page 4 of 4 FirstFirst ... 234
  1. Posts : 12,012
       #31
    Here is a possibility:
    Arctic Cooling Freezer 7 LP CPU Cooler at Koolertek.com - Koolertek
    More detail:
    Freezer 7 LP · CPU · Cooling · Arctic Cooling
    very low profile; includes thermal paste; It is a pwm fan and I don't know what rpm it would run at on your motherboard;
    Here is another; not as low profile, but probably low enough; you'd have to search for a dealer as newegg and koolertek are out of stock; it may be discontinued. It is also pwm.
    Alpine 7 PRO · CPU · Cooling · Arctic Cooling
    here is a review of it:
    Arctic Cooling Alpine 7 Pro Intel Heatsink Review - FrostyTech.com
    Arctic Cooling stuff is usually pretty good, but do your own research.
  2. Posts : 172
    Windows 7 Home premium 64bit SP 1
       #32
    Thanks, I'll take a look at the "Freezer 7 LP".
    I don't know much about "Pulse-width Modulation" or how to tell if my system supports it, but I can tell you that as the load increases on the processor the old "Snail-Fan" speed increases immensely, sounds similar to a F-16 at takeoff!
    N2
