Problem with monitor...HP
  1. Posts : 118
    Windows 7 Ultimate 32
    I posted this also in the gaming section however I have now come to a conclusion that Splinter Cell is not causing the problem. Although when playing Splinter Cell the problem can happen..
    I have a HP monitor HP w1907 Wide LCD Monitor the problem is the monitor goes black and I can't see nothing. The monitor switch light is still on I switch it off then turn it back on the I can see the screen for like 2 seconds then it goes black again! So I then have to wait like one minute for the problem to fix it self. I have ruled out that my Graphics card is fine because I have a second monitor without problems. I also booted in Safe Mode and I don't have the problem there! So I am ruling out that it is software/driver related. My Graphics Card Driver is up to date..
    However my monitor driver is odd. I have the CD but can't still driver because of an "unexpected error" (I think cause I am on Windows 7 ultimate 32bit)
    OK Besides that in Device Manager it says:
    This device is working properly.
    But it also says this on the driver tab
    Driver: Provider: is Unknown
    Date, Version: Is not available
    Digital Signer: Not digitally signed
    Has anyone got any suggestions thanks..
    (Graphics Card is ATI Radeon HD 3450)
  2. Posts : 2,588
    Critical,
    You can try looking for an updated driver for your monitor (windows 7 32 bit) on the manufacturer's website. However, it is unlikely that this is the problem, as windows installs a generic one if it is missing. Now, you say you can play the full screen application with another monitor just fine, have you tried putting the problem monitor with another computer and starting a full screen app, such as a game? If it doesn't work, it proves the monitor is to blame. Do you use the same cables and ports for both monitors when you switch them?
  3. Posts : 118
    No I have two screens, the other screen is connected via DVI to VGA. I work with two monitors so I don't switch cables, plus like I said if the problem is not happening in safe mode then it is a driver / software issues I guess. I disabled the driver for the monitor and the problem only happened once but worked fine...I could try uninstalling the monitor driver then re-installing (I will let windows find it.)
  4. Posts : 2,588
    Perhaps this doesn't even need to be said, but just in case: when you use a full screen app, one monitor will go blank while the other should be fine.
    tell me how all the monitors are connected in more detail if you can. switch the monitors again but use the troubled monitor's cabling and see if it has the same problems. Make sure you also use the troubled monitor's port in the graphics card.
    Sorry, you said the problem isn't happening in safe mode.
    update your system specs for me: Fill out your system specs (this tool may help you out a great deal).
  5. Posts : 2,588
    Download Revo uninstaller and remove both your monitor's driver and all of your graphics card drivers. Then download the correct ones. if you fill out your specs, I can show you where.
    Unknown to many people, poor performing AVs can cause problems. What AV do you have?
  6. Posts : 118
    Sorry what does AV Mean?
    Anyway from DxDiag:
    System Information
    Time of this report: 12/29/2011, 22:04:30
    Machine name: ASIM-PC
    Operating System: Windows 7 Ultimate 32-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.111025-1505)
    Language: English (Regional Setting: English)
    System Manufacturer: HP-Pavilion
    System Model: KP304AA-ABU a6421.uk
    BIOS: Phoenix - AwardBIOS v6.00PG
    Processor: AMD Athlon(tm) 64 X2 Dual Core Processor 4400+ (2 CPUs), ~2.3GHz
    Memory: 3072MB RAM
    Available OS Memory: 3070MB RAM
    Page File: 2412MB used, 3726MB available
    Windows Dir: C:\Windows
    DirectX Version: DirectX 11
    DX Setup Parameters: Not found
    User DPI Setting: Using System DPI
    System DPI Setting: 96 DPI (100 percent)
    DWM DPI Scaling: Disabled
    DxDiag Version: 6.01.7601.17514 32bit Unicode
    DxDiag Notes
    Display Tab 1: No problems found.
    Display Tab 2: No problems found.
    Sound Tab 1: No problems found.
    Sound Tab 2: No problems found.
    Sound Tab 3: No problems found.
    Sound Tab 4: No problems found.
    Input Tab: No problems found.
    DirectX Debug Levels
    Direct3D: 0/4 (retail)
    DirectDraw: 0/4 (retail)
    DirectInput: 0/5 (retail)
    DirectMusic: 0/5 (retail)
    DirectPlay: 0/9 (retail)
    DirectSound: 0/5 (retail)
    DirectShow: 0/6 (retail)
    Display Devices
    Card name: ATI Radeon HD 3450
    Manufacturer: ATI Technologies Inc.
    Chip type: ATI display adapter (0x95C5)
    DAC type: Internal DAC(400MHz)
    Device Key: Enum\PCI\VEN_1002&DEV_95C5&SUBSYS_11811462&REV_00
    Display Memory: 1530 MB
    Dedicated Memory: 251 MB
    Shared Memory: 1279 MB
    Current Mode: 1440 x 900 (32 bit) (60Hz)
    Monitor Name: Generic PnP Monitor
    Monitor Model: unknown
    Monitor Id: CVT4668
    Native Mode: 1440 x 900(p) (60.169Hz)
    Output Type: HD15
    Driver Name: atiu9pag.dll,aticfx32.dll,atiumdag.dll,atidxx32.dll,atiumdva.cap
    Driver File Version: 8.14.0001.6099 (English)
    Driver Version: 8.712.1.0
    DDI Version: 10.1
    Driver Model: WDDM 1.1
    Driver Attributes: Final Retail
    Driver Date/Size: 3/10/2010 22:33:04, 20480 bytes
    WHQL Logo'd: Yes
    WHQL Date Stamp:
    Device Identifier: {D7B71EE2-D685-11CF-0160-8031A1C2C535}
    Vendor ID: 0x1002
    Device ID: 0x95C5
    SubSys ID: 0x11811462
    Revision ID: 0x0000
    Driver Strong Name: oem38.inf:ATI.Mfg.NTx86.6.0:ati2mtag_RV610:8.712.1.0ci\ven_1002&dev_95c5&subsys_11811462
    Rank Of Driver: 00E60001
    Video Accel: ModeMPEG2_A ModeMPEG2_C
    Deinterlace Caps: {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
    {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
    {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
    {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
    {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
    {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
    {3C5323C1-6FB7-44F5-9081-056BF2EE449D}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
    {552C0DAD-CCBC-420B-83C8-74943CF9F1A6}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
    {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
    {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
    {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
    D3D9 Overlay: Not Supported
    DXVA-HD: Not Supported
    DDraw Status: Enabled
    D3D Status: Enabled
    AGP Status: Enabled
    Monitor Name: HP w1907 Wide LCD Monitor
    Monitor Model:
    Monitor Id:
    Native Mode:
    Output Type:
    DDI Version: 10.1
    WHQL Logo'd: Yes
    WHQL Date Stamp:
    Vendor ID: 0x1002
    Device ID: 0x95C5
    Revision ID: 0x0000
    D3D Status: Enabled
    AGP Status: Enabled
    Sound Devices
    Description: Speakers (Realtek High Definition Audio)
    Default Sound Playback: Yes
    Default Voice Playback: Yes
    Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0888&SUBSYS_103C2A6C&REV_1001
    Manufacturer ID: 1
    Product ID: 100
    Type: WDM
    Driver Name: RTKVHDA.sys
    Driver Version: 6.00.0001.6316 (English)
    WHQL Logo'd: Yes
    Date and Size: 2/24/2011 17:21:12, 3408808 bytes
    Other Files:
    Driver Provider: Realtek Semiconductor Corp.
    HW Accel Level: Basic
    Cap Flags: 0xF1F
    Min/Max Sample Rate: 100, 200000
    Static/Strm HW Mix Bufs: 1, 0
    Static/Strm HW 3D Bufs: 0, 0
    HW Memory: 0
    Voice Management: No
    EAX(tm) 2.0 Listen/Src: No, No
    I3DL2(tm) Listen/Src: No, No
    Sensaura(tm) ZoomFX(tm): No
    Description: Speakers (Bluetooth AV Audio)
    Default Sound Playback: No
    Default Voice Playback: No
    Hardware ID: {F12D3CF8-B11D-457e-8641-BE2AF2D6D204}\BLUELETAUDIO
    Manufacturer ID: 1
    Product ID: 100
    Type: WDM
    Driver Name: blueletaudio.sys
    Driver Version: 6.00.0013.0061 (English)
    WHQL Logo'd: Yes
    Date and Size: 5/11/2007 02:10:50, 34704 bytes
    Other Files:
    Driver Provider: IVT Corporation
    Cap Flags: 0xF1F
    HW Memory: 0
    Description: Speakers (Bluetooth SCO Audio)
    Hardware ID: {F12D3CF8-B11D-457e-8641-BE2AF2D6D204}\BLUELETSCOAUDIO
    Manufacturer ID: 1
    Product ID: 100
    Type: WDM
    Driver Name: BlueletSCOAudio.sys
    Driver Version: 6.00.0012.0056 (English)
    WHQL Logo'd: Yes
    Date and Size: 3/5/2007 05:00:04, 27792 bytes
    Other Files:
    Cap Flags: 0xF1F
    HW Memory: 0
    Description: Realtek Digital Output (Realtek High Definition Audio)
    Manufacturer ID: 1
    Product ID: 100
    Type: WDM
    WHQL Logo'd: Yes
    Other Files:
    Cap Flags: 0xF1F
    HW Memory: 0
    Sound Capture Devices
    Description: Stereo Mix (Realtek High Definition Audio)
    Default Sound Capture: Yes
    Default Voice Capture: Yes
    Cap Flags: 0x1
    Format Flags: 0xFFFFF
    Description: Microphone (Bluetooth SCO Audio)
    Default Sound Capture: No
    Default Voice Capture: No
    Cap Flags: 0x1
    Description: Microphone (Bluetooth AV Audio)
    Cap Flags: 0x1
    DirectInput Devices
    Device Name: Mouse
    Attached: 1
    Controller ID: n/a
    Vendor/Product ID: n/a
    FF Driver: n/a
    Device Name: Keyboard
    Attached: 1
    Controller ID: n/a
    FF Driver: n/a
    Device Name: CTH-460
    Attached: 1
    Controller ID: 0x0
    Vendor/Product ID: 0x056A, 0x00D1
    FF Driver: n/a
    Attached: 1
    Controller ID: 0x0
    FF Driver: n/a
    Device Name: Wacom Virtual Hid Driver
    Attached: 1
    Controller ID: 0x0
    Vendor/Product ID: 0x056A, 0x1001
    FF Driver: n/a
    Attached: 1
    Controller ID: 0x0
    FF Driver: n/a
    Attached: 1
    Controller ID: 0x0
    FF Driver: n/a
    Poll w/ Interrupt: No
    USB Devices
    + USB Root Hub
    | Vendor/Product ID: 0x10DE, 0x03F1
    | Matching Device ID: usb\root_hub
    | Service: usbhub
    | Driver: usbhub.sys, 3/25/2011 02:58:37, 258560 bytes
    | Driver: usbd.sys, 3/25/2011 02:57:53, 5888 bytes
    Gameport Devices
    PS/2 Devices
    + Enhanced Multimedia PS/2 Keyboard
    | Matching Device ID: acpi\pnp0303
    | Upper Filters: PS2
    | Service: i8042prt
    | Driver: PS2.sys, 12/12/2005 16:27:00, 19072 bytes
    | Driver: i8042prt.sys, 7/13/2009 23:11:24, 80896 bytes
    | Driver: kbdclass.sys, 7/14/2009 01:20:36, 42576 bytes
    + Terminal Server Keyboard Driver
    | Matching Device ID: root\rdp_kbd
    | Upper Filters: kbdclass
    | Service: TermDD
    + PS/2 Compatible Mouse
    | Matching Device ID: *pnp0f13
    | Service: i8042prt
    | Driver: mouclass.sys, 7/14/2009 01:20:44, 41552 bytes
    + Wacom Mouse Monitor
    | Matching Device ID: hid\vid_056a&pid_00d1&mi_00&col01
    | Upper Filters: wacmoumonitor
    | Service: mouhid
    + Wacom Mouse
    | Matching Device ID: hid\wacomvirtualhid&col03
    | Upper Filters: wacommousefilter
    | Service: mouhid
    | Driver: wacommousefilter.sys, 10/5/2010 12:26:02, 11312 bytes
    | Driver: mouhid.sys, 7/13/2009 23:45:08, 26112 bytes
    + Terminal Server Mouse Driver
    | Matching Device ID: root\rdp_mou
    | Upper Filters: mouclass
    | Service: TermDD
    | Driver: termdd.sys, 11/20/2010 12:30:12, 53120 bytes
    | Driver: sermouse.sys, 7/13/2009 23:45:08, 19968 bytes
    Disk & DVD/CD-ROM Drives
    Drive: C:
    Free Space: 164.4 GB
    Total Space: 238.3 GB
    File System: NTFS
    Model: ST336032 0AS SCSI Disk Device
    Drive: F:
    Free Space: 2.5 GB
    Total Space: 20.5 GB
    File System: NTFS
    Model: Seagate Desktop USB Device
    Drive: G:
    Free Space: 21.2 GB
    Total Space: 105.1 GB
    File System: NTFS
    Drive: U:
    Free Space: 325.4 GB
    Total Space: 456.5 GB
    File System: NTFS
    Drive: D:
    Model: ATAPI DVD A DH16A3L SCSI CdRom Device
    Driver: c:\windows\system32\drivers\cdrom.sys, 6.01.7601.17514 (English), 11/20/2010 08:38:10, 108544 bytes
    Drive: M:
    Model: ELBY CLONEDRIVE SCSI CdRom Device
  7. Posts : 4,280
    Please use one of these programs to list your system specs in the user cp edit system specs here.
    Speccy http://www.piriform.com/speccy/download
    HWiNFO http://majorgeeks.com/HWiNFO_d279.html
    This makes it much easier for members to click on the "My System Specs at the bottom of your post.
    AV stands for Anti-Virus
    Thanks Fabe
  8. Posts : 118
    OK I updated my specs.
    oh and I am using Microsoft Security Essentials..
    OK I tried to update it using Device Manager but get error "Access is Denied" I am admin..
  9. Posts : 2,588
    For now, update the GPU here: ATI Catalyst
    You will need to have removed the previous one
  10. Posts : 118
    I did in fact I already had this anyway. However I uninstalled the drivers and stuff and let windows find the monitor which it did and it used Windows Update to update it. However when I play Splinter Cell the screen for some reason can go off, but will come back on after a minute it maybe the game since other games work fine...
    Let see how it goes..
